  • July 13, 2025, 01:36:16 AM
Author Topic: finished Impact  (Read 3859 times)
Offline Steve Bakac
finished Impact
« on: December 15, 2012, 06:05:47 PM »
G/day Guys
                 Just finished my Arc Impact from Steve moon ,went together really well,no real hicups.Only change was that i took out crimped leadouts n redone them wrapped.Came in at 68oz ready to fly.
Test flight shortly
Bucky
Offline Steve Bakac
Re: finished Impact
« Reply #1 on: December 15, 2012, 06:07:48 PM »
Just a few more
Offline Dan Bregar
  • Field Marshall
Re: finished Impact
« Reply #2 on: December 15, 2012, 06:54:55 PM »
Bucky
Nice job mate !  What motor, batt. & ESC are you using ?
AMA 33676
Offline Steve Bakac
Re: finished Impact
« Reply #3 on: December 15, 2012, 07:54:11 PM »
Hi Dan
          Running a Emax 2832/05 , ZTW 50amp esc , KR2timer ,3300 turnigy battery and starting with 12 x 6 pusher
 Bucky
Re: finished Impact
« Reply #4 on: December 16, 2012, 03:21:23 PM »
Another awesome looking stunt plane.
Re: finished Impact
« Reply #5 on: December 16, 2012, 03:31:08 PM »
With hatches both on top and bottom, I'd worry about the nose falling off.
Re: finished Impact
« Reply #6 on: December 16, 2012, 09:33:48 PM »
Great color scheme - simple and to the point.  Weight sounds good too.
Offline Steve Bakac
Re: finished Impact
« Reply #7 on: December 17, 2012, 02:57:37 AM »
Thanks guys for the compliments
 G/Day Howard   It only has the top hatch to hold battery in when locked down and the side are extended down and shaped so no need for a cowl , bottom is left open for cooling , I also have a ply battery floor glue in to stiffen the nose up as well corner gussets in and around it as too the ply motor mount which goes almost the the bottom of side.As well i have left about a 3/32 of the bearers in .Hope this help
Re: finished Impact
« Reply #8 on: December 17, 2012, 02:39:45 PM »
I have been interested in trying a top hatch, but a structures guy familiar with this airplane advised me against it.  I'm looking forward to seeing how yours works.
It's good that you have cooling air going to the stuff that needs cooling.  Mine didn't, so I had to make silly internal ducts.
We have found (PW has found, and eventually convinced me) that the battery CG for these airplanes should be approximately at the wing centerline.  Looks like yours is closer than where mine started.
Pretty airplane.  I think the aft section color is particularly tasteful.
Re: finished Impact
« Reply #9 on: December 18, 2012, 07:50:04 AM »
CG at wing center line ?
So does that mean evenutally we will see a redesign for ELC specfic lifting wings with a more rearward highpoint?
Re: finished Impact
« Reply #10 on: December 18, 2012, 12:55:50 PM »
Vertical battery CG.
Online Steve Helmick
Re: finished Impact
« Reply #11 on: December 18, 2012, 07:46:00 PM »
Yes, nice yellow! Surprised the rest isn't Kelly (?) Green, tho.  y1  Steve
Offline Ron Heckler
Re: finished Impact
« Reply #12 on: December 18, 2012, 09:21:08 PM »
Looks good Steve.  Lots of luck with it.
Ron
Offline Andrew Borgogna
  • Andy
Re: finished Impact
« Reply #13 on: December 18, 2012, 11:07:29 PM »
Yet another electric wonder from the land down under! ;D  Really nice.
Andy
Andrew B. Borgogna
Offline Dean Pappas
Re: finished Impact
« Reply #14 on: December 19, 2012, 06:53:45 PM »
Hi Howard,
Do you mean that he suggested to center the "massive" battery vertically on the leadout position?
Is this for some dynamic balance issue?
  Dean P.
Dean Pappas
Re: finished Impact
« Reply #15 on: December 19, 2012, 08:47:40 PM »
Just to be clear:
Offline Steve Bakac
Re: finished Impact
« Reply #16 on: December 20, 2012, 12:36:33 AM »
Thank you Howard understand clearly  and I will try this .
Test flown and with all the cooling i have it still over heated badly from the motor , Esc n battery. Back to the drawing board .Set up im running was 12/6p n 13/5.5 WP set 9300rpm 4s 3300 battery put 2140 back in after 5.30min flight. more cooling i suppose to handle the 40c heat here in the outback.
Re: finished Impact
« Reply #17 on: December 20, 2012, 06:30:39 AM »
Steve : Are you goign to the Nats ?
Offline Dean Pappas
Re: finished Impact
« Reply #18 on: December 20, 2012, 10:19:19 AM »
Just to be clear:
Hi Howard,
Sure enough, that was clear. Now, WHY?
This should be educational, no?
Dean
Dean Pappas
Re: finished Impact
« Reply #19 on: December 20, 2012, 01:05:06 PM »
Now, WHY?
It's a Mystery of Stunt.  Putting the battery on the wing centerline is just a rule of thumb, and applies only to Impacts as far as I know.
Offline Steve Bakac
Re: finished Impact
« Reply #20 on: December 20, 2012, 02:00:14 PM »
Hi PJ
           Yep Ill be there but wont be bringing the Impact for this one just haven't got time to work on it .So ill bring  my old fatefull  (Europa).
 Will you be there with your newie or you still buffing the wheels?
Re: finished Impact
« Reply #21 on: December 21, 2012, 04:30:34 AM »
Steve : No wheel's were buffed out ages ago..
I'l have the new one.......  yes.
I just hope I can test fly and trim prior to the Nats..... b1
