  • July 30, 2025, 04:56:36 PM
Author Topic: Field Charger power supply  (Read 1328 times)
Offline Bill Mohrbacher
« on: August 21, 2009, 08:48:21 AM »
I was browsing Harbor Freight yesterday and found a dandy little 800 watt generator (item 66619) for $109.99.  It puts out only 120 VAC, no 12VDC.  It is very compact, weighs 40#.  I was going to buy a deep cycle battery.   They cost $67 in my area and a good charger for it is another $50, so this little generator seems a good deal to me.  I'm using a 5S2P 2300 mAH A123 battery in my RC Focke Wulf and don't want to charge it from my car battery.
I already have a good 120VAC-12 VDC power supply (an IBM hot swappable server PS 12VDC @ 37 amps) I use to power my FMA Cellpro charger so I can just plug it into the generator.
Re: Field Charger power supply
« Reply #1 on: August 21, 2009, 01:43:39 PM »
Now THAT sounds like a good deal  Have you got it and tried it out yet?
« Reply #2 on: August 21, 2009, 07:11:15 PM »
I just fired it up this afternoon.  I used my IBM 120VAC power supply to run my FMA Cellpro 10 to charge my 5S2P at 10 A.  The generator powered the IBM just fine.  I didn't monitor the 120, but the IBM was able to supply 12.3 VDC @ 25 amps to the Cellpro (25 A is the max input current the Cellpro will draw).
Also, it starts right up.  I'll be using it at a Warbirds flyin tomorrow near Youngstown, so I'll give it moreof a workout.  I'm happy.
Offline Richard Grogan
« Reply #3 on: August 21, 2009, 08:26:26 PM »
How loud is it? Is it going to drive the other pilots batty? Pretty cool idea if you can get away with it!
Long Live the CL Crowd!
                  AMA 85745
« Reply #4 on: August 21, 2009, 08:45:19 PM »
RG:
I think if ya mix just a touch of castor with the gas, it will help PACIFY the on electric contingent!  #^
Online Crist Rigotti
« Reply #5 on: August 21, 2009, 09:42:36 PM »
RG:
Now that's funny!
Alan Hahn
« Reply #6 on: August 22, 2009, 08:52:49 AM »
RG:
Well I'd put it next to Russ and crank it up during my flight!
« Reply #7 on: August 22, 2009, 03:41:57 PM »
At an electric meet it may be loud.  At a glow meet--YOU GOT TO BE KIDDING!!
Seriously, it is quite quiet.  Way quieter than weedwackers, leaf blowers, etc.
Offline Dean Pappas
« Reply #8 on: August 23, 2009, 03:03:22 PM »
The gold standard for quiet in this size would be a Honda 1000W generator. Can you compare the sound level to one of those?
Dean P.
Dean Pappas
Offline Igor Burger
