  • July 12, 2025, 11:22:23 PM
Author Topic: feel of outrunners when turned over  (Read 776 times)
Offline keith varley
« on: November 26, 2012, 03:40:29 PM »
I've noticed that all outrunners don't feel the same when gently turned over manually. MY Axi motors feel much more "NOtCHY" than the E Flights motors of my friends.  Also one of my Axi motors doesn't feel nearly as Notchy as the other ones I have. And yet they seem to work as expected.   I realize that it's probably the strength of the magnets , or how close they are to the can. Inquiring minds need to know. Should one be concerned at all with the feel?
What gives? Keith
Re: feel of outrunners when turned over
« Reply #1 on: November 26, 2012, 03:53:11 PM »
The official term is "cogging", and it depends on more than you think.
Basically, the motor wants to relax into a position where the magnets are as close as possible to as much iron as possible.  Pull the motor away from this position, and it wants to pull back.  Pull it far enough, and it goes "over the hill" and it wants to advance to the next cog instead of the one that it had been on.
All motors that have an iron armature that rotate with respect to the magnets exhibit at least some cogging torque.  There are, in fact, high-zoot motors available that have windings that are molded "in the air" and have no iron attached -- search on "coreless motor"; they're pretty much de rigueur for servo motors, both RC and industrial.
This cogging torque depends on the strength of the magnets, and on the width of the gaps in the armature, and on how much gap there is between armature and magnet, and on the width of the gaps between the magnets, and on whether the gaps in the armature are staggered or not, and probably on a few other things that I don't know of or haven't remembered.  Motor manufacturers can significantly reduce the cogging torque without affecting the overall motor torque much by constructing the armature so that the gaps are a bit skewed to the axis of rotation -- that way, the magnets "see" the gap at different angles of rotation along the length of the armature, which has the effect of making the gap "look" softer to the magnets, and you have less cogging torque.  This is probably what eFlight does.
I don't think you need to be hugely concerned about this.  Cogging torque is an issue, because it's always there and may be part of what makes motor bells resonate at just the wrong frequency.  But except for certain motors, I don't believe that its a huge issue.
Offline Dave Denison
« Reply #2 on: November 26, 2012, 08:33:26 PM »
Tim.
Thanks for the great explanation.  I've read many statements on "cogging" over the years but yours spells it all out very well.
  regards.
  Dave.
ama 41041
« Last Edit: November 26, 2012, 10:23:02 PM by Dave Denison »
ama 41041
« Reply #3 on: November 26, 2012, 10:06:41 PM »
Tim:     Like I told you at the Fall Follies---You sure know a lot of "stuff".Keith
