  • July 01, 2025, 05:48:47 PM
Author Topic: FancyFoam Yak 55 indoor electric  (Read 2635 times)
Offline bob branch
« on: February 02, 2011, 01:19:57 PM »
A year or two ago someone, I think it was Igor did a thread on a Fancyfoam Yak 3D rc plane converted to indoor electric. I am just finishing one and need some input on the leadout guide. If anyone knows the link to the thread could you post it. Also wanted to know what prop you were using. My guess from motor size and amps that I have read about this year it was about 10X4.7 inch slow flier. What rpms were you flying?
My primary question is the leadout guide is causing an aileron deflection downwards due to gravity. Did you put a carbon fiber rectangular strip along your trailing edge to minimize this or just fly with it and let it help lift the lines. Inverted gravity will pull it the other way and overhead it will go neutral. Doesn't sound like a good system to me but considering it made me pause before I did the carbon fiber and ask what you did.
bob branch
planning first flight on Monday.
 H^^
Offline Igor Burger
Re: FancyFoam Yak 55 indoor electric
« Reply #1 on: February 02, 2011, 01:31:24 PM »
Bob, yes, the prop is 10x4.7 and rpm set to ~4500.
I do not know what you mean about aileron and gravity ets, may be if you can make some pictures ....
BTW you can find lot of details in this thread: http://stunthanger.com/smf/index.php?topic=19265.0
Offline bob branch
« Reply #2 on: February 02, 2011, 01:45:17 PM »
Igor
Ah, now I see what you did. I put too much stucture out there. The Fancyfoam Yak (Gernot Bruckman's plane) has much larger ailerons I locked them with some tiny foam tabs and have my leadout guide mounted on the outboard end of the ailerons. But I have enough weight in them that the  thin depron flexes downward at the outboard end. Obviously looking at what you are doing I have too much structure so I'll get rid of it and solve the entire issue.
bob branch
Harsens Island, Michigan
Offline bob branch
« Reply #3 on: February 02, 2011, 05:29:51 PM »
photos
Offline bob branch
« Reply #4 on: February 02, 2011, 05:34:24 PM »
more photos
control system layout
leadout guides -1/64 ply doublers, delron guide from tuned pipe hanger attached with tapped 4X40 bolt - adjustable via different holes
bellcrank - 1/32 ply doublers, sig 2 1/2 bellcrank with 4 inch 1/32 ply overlay. Carbon fiber pushrod
Offline bob branch
« Reply #5 on: February 02, 2011, 05:42:25 PM »
setup:
Fancyfoam Yak 55
turnigy 2826 1350 KV
turnigy plush esc
gws 10X4.7 slow flyer prop
turnigy 500 2S lipo
Will Hubin fm2-A timer
15 ft spider wire lines
bench test showed 2 min static draw 390 mah at 6000 rpm. Initial rpm will be 4800.
initial tests will be Monday night.
bob branch
Offline Igor Burger
« Reply #6 on: February 03, 2011, 08:21:09 AM »
Now I understand, LO guide is on "movable" part of the wing, I would try to glue it by CA glue to the wing ... but you know what to do :-)
I need ~550mah from 800mah battery for full program and it takes ~ 4:40min
Offline Vincent Judd
« Reply #7 on: November 16, 2011, 03:06:07 PM »
Please pardon me for ressurecting an old thread, but we recently came across a great indoor faciltiy and besides my usual assortment of indoor foamie R/C stuff, I was approached by one of my buddies who knows about my C/L activities and wanted me to build something to fly C/L indoors.
I immediately thought of this forum.  I started searching and came upon this thread and Igor's thread.  Both are very interesting and contain a lot of interesting information.  I don't have a lot of time to design, I was hoping to get something that I could purchase, build and fly.
Bob, if you're out there, any feedback on initial flight performance of the Yak?  Did the project just die out or have you developed something else?
Anyone else tried to come up with a successful indoor C/L design?  I'd appreciate any and all information.
« Reply #8 on: November 16, 2011, 03:11:05 PM »
Igor is the man when it comes to indoor CL, at least on this forum.
You might try searching on Igor's name and "indoor" from the forum main page -- something like 'Igor Burger indoor' should cough up a whole bunch of threads.
« Reply #9 on: November 16, 2011, 04:21:15 PM »
I found all of Igor's stuff Tim, but it doesn't look like his kits sell in this country.  I was looking for something I could purchase and fly rather quickly.
Offline bob branch
« Reply #10 on: November 16, 2011, 04:58:34 PM »
Vince
The fancy foam yak suffered from too much wing flex. I converted it to rc where it is wonderful as is well known. I also built one of Igor's models and flew it indoors. Controls came out way too fast but I only got to fly it a few times last year. Our club does not start flying indoors til just after the first of the year when I'm planning on going back to it and slowing down the control system. The layout of the supports under his wing gives it a lot more stability as does the lack of flaps. The wing area of his planes are larger than the fancy foam yak plus the underwing support system really adds a considerable amount of area as well so the wing loading goes down and of course that drops the required airs peeds. I have no paved area to fly on during the summer season and it would require paved surface and absolute zero winds. I live on an island where several rivers come into a large lake. It is rarely zero wind here, almost none at all this year. I would really like to see more folks flying indoors around here. The gym we fly at was remodeled during the summer. Hopefully we will get some of the ceiling obstructions gone. Still waiting to see.
Igor, what weight motor in grams and what kv are you running?
bob branch
Offline Igor Burger
« Reply #11 on: November 17, 2011, 01:12:00 AM »
Hi Vince, that my "BG like" indoor is designed for c/l stunt and so far the best indoor for c/l I know. It is produced as a kit in Czech and I know that guy who makes it had lot of troubles sending it by post. Postmans tend to fold it etc (it is in nice paper box, just potmans are litle bit ... %#*(*(**&&^ ) so yes, it is not available near you.
However you can use kits for F3P or F3AI ... simply stunt r/c indoors of that size. I tried it, you can see pictures here:
http://www.rcmodely.sk/CLClik/
and its flight is here:
The difference is shorter nose section of those kits, it is not good for us, but I can say it still fly whole our program. If you choose from kits, try to take that one which has ailerons still attached so you not need to stick it bac, try to find that one which has large nose and choos that one which has lot of side area (large fuselage, side thrust makers on wing)
or simply cut that model yourself, you need only plate of 3mm thick foam and sharp knife. I can send you plan, or you can find well done plan somewhere here on forum from Spain guys if I remember well.
Offline Igor Burger
« Reply #12 on: November 17, 2011, 01:24:46 AM »
Bob, I use special motor made here close to us, it is 1400rpm/V, but important is internal resistance, it is only 150mohm ... that large 10" prop loads it lot, so the resistance is very important thing. It is 32g heavy with back support and prop driver (2 screws directly in the body). I you will choose from cheaper chinese production, you will end up little heavier, but several guys here used Emax CF2822 with success, but its weight is 45g in the same configuration. So that is why that my model has little more area than ususal F3A indoor.
TO RPM is 4500 so that is the power which the motor must deliver on ground. I use 800mah battery and I need ~550mah for 5 minute long flight. Lap time on 5m long lines is 4.9 - 5 s
Offline bob branch
« Reply #13 on: November 17, 2011, 05:21:29 AM »
Igor
Yes, I noticed I had to go up in motor size from what you had used. Its a suprising large model and very nicely designed. I just wish it was strong enough to land on grass. But that would defeat the purpose indoors.
thanks,
bob branch
Offline Igor Burger
« Reply #14 on: November 17, 2011, 05:43:01 AM »
I think landing on grass is not big problem, when motor stops, model stalls anyway, and it falls like a piece of paper if you do not whip it little bit :- )))
Offline bob branch
« Reply #15 on: November 17, 2011, 05:54:47 AM »
Igor
Good morning.... well, evening on your side I guess. I had been worried about the undercarriage, but then grass may be more gentle than a gym floor. OK, I'll give it a try at our next calm weather CL practice session. Problem is it looks like winter has arrived here in Michigan. Our last 4 practice sessions have been cancelled due to wind. I think we are probably done outdoors for the year now. But in January we will get at it indoors. Rick Sawicki is one of my flying partners and has talked about making the couple hour drive to my place to fly indoors. He has several models he flew indoor a number of years back. Don't know how long back, but he has been in electric for many years.
bob branch
Offline Igor Burger
« Reply #16 on: November 17, 2011, 06:02:56 AM »
here you can see my prototype .. it did not have any wheels, motor is strong enough to take it up, and landing was rather falling than gliging  ;D
just be carefull, if will not start easy from conrete, it will tend to flip to nose because of friction, but you can start from hand ... starteng from floor in gym is not big problem
