  • August 02, 2025, 05:40:19 PM
Author Topic: Li Po Battery for an Oriental Arf  (Read 2745 times)
Offline petermick
« on: April 25, 2014, 09:58:33 AM »
I am near the completion of my first electric powered plane.  The plane is a Brodak Oriental Arf.  It's finished weight hopefully will be no more than 45 oz. It will be powered by an E-Flight 15 using a Castle Lite 50 ESC and a Hubin FM 9 Timer.  I want to use a 2400 to 2700 4S 30C battery.  When I look at the List Your Setup string I can't find any consensus as to what brand of battery to use.  I am looking for recommendations.
Peter Mick
AMA 9581
Offline John Cralley
Re: Li Po Battery for an Oriental Arf
« Reply #1 on: April 25, 2014, 10:16:16 AM »
I've had good luck with GenAce batteries from Hobby Partz. You can get a couple for what a top of the line battery will cost.
Others will have their opinions.  😂
John Cralley
AMA 52183
Central Illinois
Offline Dan Bregar
  • Field Marshall
« Reply #3 on: April 28, 2014, 05:58:49 PM »
I have a couple of the Zippy compacts similar to the link Crist just posted, and they seem pretty good so far.  :)
AMA 33676
« Reply #4 on: April 28, 2014, 07:03:55 PM »
I think the "consensus" is that most anything will do.  Having said that, the absolute top flyers prefer one or two of the absolute top brands (Thunderpower?  I dunno -- I fly 'lectric RC, but slime CL).
Offline Target
  • C/L Addict
« Reply #5 on: April 15, 2015, 12:59:05 PM »
I'm thinking that the Hyperion batteries represent a good quality mid-priced LiPo.
Less money than a Thunder Power, but more than the HK batteries. Very likely better QC and return policies as well.
http://www.amazon.com/Hyperion-G3-Lithium-Polymer-Battery/dp/B003YIACPI
I'll probably get one each of a few brands and see if I can tell the difference for my first go around in ECL, which will also be with an Oriental. ;)
Chris
Chris
AMA 5956
Offline Target
  • C/L Addict
« Reply #6 on: May 17, 2015, 08:32:21 PM »
I have two Hyperion 4S 2500's coming, and already have two of the 4S Thunder Power Pro lite 2700's here....
My question is-
On ARF's like the Oriental, how many people have notched out the wing leading edge and cut a hole in the former ahead of the wing in the fuse, in an effort to get the CG right without tail weight added?
I suppose it may come down to the motor used, and how heavy it is?
I also suppose that I can mock up the assembly and see where the CG ends up before I bust out my trusty Dremel Rotory Tool.
Should I be concerned about weakening the wing by cutting the LE on this ARF?
Thanks for any advice, especially that of personal experience.
Chris Behm
Chris
AMA 5956
« Reply #7 on: May 19, 2015, 10:44:05 AM »
I have that same system on a 576 sq in plane and I use hyperion 4s 2500 mah and get flights of 5:45 min. with an 11-6.
