  • July 16, 2025, 12:41:31 PM
Author Topic: External arming plug  (Read 3190 times)
Dwayne
« on: March 18, 2017, 07:25:59 AM »
Hi all
Has anyone tried using a 1/8th in. jack as a arming plug? I was thinking about counter sinking the female on the bottom of the plane.
Offline John Tate
Re: External arming plug
« Reply #1 on: March 18, 2017, 09:20:49 AM »
Not much surface contact there. I do not think you can get enough current to go thru that connector to be effective.
« Last Edit: March 18, 2017, 11:34:14 AM by John Tate »
Offline Carl Cisneros
« Reply #2 on: March 18, 2017, 01:25:00 PM »
Too little surface contact area there.
Connection will go over the top temperature wise big time.
Carl R Cisneros, Dist IV
Control Line RB
Offline pmackenzie
  • Pat MacKenzie
« Reply #3 on: March 18, 2017, 03:28:54 PM »
As the others have said, just not enough current carrying capability.
The other thing is that you don't really want to "hide" the arming plug.
The whole point is that it is clear where it is and what it does.
MAAC 8177
« Reply #4 on: March 19, 2017, 12:41:31 PM »
blank
« Last Edit: March 06, 2022, 09:02:06 AM by Motorman »
« Reply #5 on: March 20, 2017, 07:36:27 PM »
Not nearly enough current carrying ability, by far.
Offline Phil Krankowski
« Reply #6 on: March 21, 2017, 04:19:50 PM »
Works just great on one of my gliders.  I'm driving 4 tiny servos and the RX.  Doubles as a charging port.  I have a four 1/3AA Nimh battery pack installed.
Probably pretty light for most other purposes.
Phil
« Reply #7 on: March 21, 2017, 05:45:41 PM »
I'd have to think the first pull out the plug would go right in the ground.
It might work, but if folks are correct about the current capacity, the plug might weld itself to the jack.  It would then be hard to disassemble, because the nut on the jack wouldn't come off past the plug.  The good news is that the plug wouldn't fall out when you pull out of a wingover, as Motorman feared.
« Reply #8 on: March 22, 2017, 02:11:43 PM »
This is correct.  With a "switched" jack when the plug is removed the contacts are in bypass internally, connecting and turning on the circuit.  With the plug removed the circuit is through the jack instead, allowing for charging.
This might be the thing for some OTS ignition engines with rechargeable batteries.  Plug in the charging cord disconnects the battery from the circuit.  This is the same as my use with my glider.
Phil
« Reply #9 on: March 22, 2017, 02:54:25 PM »
There are single pin plug and jacks that can carry the current, they are used on the motor and ESC connection typically
« Reply #10 on: March 23, 2017, 06:07:54 PM »
The bestest and cheapest is the Deans Ultra Plug (large 2-pin red ones).  A 16 ga. wire loop makes it easy to see and easy to pull out.
