  • June 21, 2025, 06:28:56 PM
Author Topic: Profile Electric Motor Mount  (Read 4211 times)
Offline petermick
« on: March 14, 2017, 03:50:23 PM »
Last week at VSC I purchased a beautifully finished Francherized Twister from Bob Hazel.  Bob had completed the model with an OS 25 mounted on it.  Because I have gone over to electric flying I purchased the plane without the engine and my intention is to convert it to electric.  I have never built or converted a profile.  Doing a search on the All Amped Up files I found a build thread from Christ Rigotti dated 2009 which shows an aluminum profile motor mount.  I believe Archie Adamisin suggested in this thread that this mount could possibly be produced for sale.  I am wondering if this was ever done and if so where can it be purchased.
Christ, if this was a one only piece do you have a drawing of it.
Peter Mick
AMA 9581
Offline Crist Rigotti
Re: Profile Electric Motor Mount
« Reply #1 on: March 14, 2017, 11:15:59 PM »
Pete,
Don't go the aluminum mount.  That was a long time ago and a 1 off.
Here is where I modified a Sig Primary Force for electric.  Perhaps you can glean some good info off that.
http://stunthanger.com/smf/gettin-all-amp'ed-up!/electric-primary-force/
I have done other electric profiles but I think they were electric from the get-go.  I'll look and see.
http://stunthanger.com/smf/gettin-all-amp'ed-up!/2013-electric-stunter-a-build-log/msg280697/#msg280697
« Reply #2 on: March 15, 2017, 09:09:21 AM »
you might also contact Pat Johnston, he has been laser cutting some really cool battery holder box motor mount assemblies that work a treat
Online Motorman
« Reply #3 on: March 15, 2017, 01:46:05 PM »
blank
« Last Edit: March 06, 2022, 09:05:57 AM by Motorman »
« Reply #4 on: March 15, 2017, 10:02:13 PM »
Hi Peter
You are going to need a battery box too, I really like the idea of integrating the firewall with the battery box because supports around the perimeter and keeps battery space clear.  Shown below is the Brodak BH-1938, shown installed in a Brodak Mauler Profile. Basically you build the box, cut a 1.75" x 7" slot in the fuselage and install the box.  The motor and battery are also centered on the fuselage, battery installed from the INBOARD side.  Not too hard a conversion even on a built bird.
Hard to beat at $7.99.  Link to the item: http://brodak.com/electric-accessories-1/conversion-kits/warbird-electric-conversion.html
Offline petermick
« Reply #5 on: March 16, 2017, 12:57:58 PM »
Christ, Mark and Dennis,
I want to thank the three of you for your very helpful responses.
Christ, I have a few questions regarding your 2013 building thread. 1) Is the motor only mounted on the front and not supported on the rear?  2) I noticed you used a Hubin timer.  Where did you mount the red start button that usually accompanies a Hubin timer?  3) Where did you mount the arming plug?
Please forgive me if I missed any of these items in your thread.
Pete
Online Motorman
« Reply #6 on: March 16, 2017, 01:46:17 PM »
blank
« Last Edit: March 06, 2022, 09:05:36 AM by Motorman »
Offline petermick
« Reply #7 on: March 16, 2017, 02:10:37 PM »
Motorman,
I'm sure your post was very helpful, unfortunately it never showed up on the thread I started.
Pete
Offline David Hoover
« Reply #8 on: March 16, 2017, 02:52:01 PM »
Motorman,
Pete
Fourth post in the thread, right after Mark's.
Best, Hoovie
Offline James Mills
« Reply #9 on: March 16, 2017, 05:04:56 PM »
Peter,
We have converted several profiles to electric using 3/8 or 1/2" angle aluminum bought from Lowe's or Home Depot.  It's a rear mount set up, got the idea from Will DeMauro, he's had pics of this conversion in some of his past columns in Stunt News.  I found a couple of pics.  This first one is before the mounts were finished out to look nicer.  The second was an old profile I picked up from Allen for Ben.
James
AMA 491167
Offline petermick
« Reply #10 on: March 16, 2017, 05:52:02 PM »
Motorman
My sincerest apology for my oversight.  This was a senior brain fart.
Pete
« Reply #11 on: March 16, 2017, 07:10:14 PM »
Pete
Pete:
1) Yes, front mounted only.
2) The Hubin timer (FM9 IIRC) I used has the start button on the timer.  It is not separate from the timer.
3) No arming plug needed.  I simply disconnect the battery from the ESC.  Everything is out in the open.
Offline petermick
« Reply #12 on: March 18, 2017, 06:45:51 PM »
Christ,
Thanks for your info.
Pete
« Reply #13 on: March 18, 2017, 06:47:16 PM »
Christ,
Pete
Say Hi to all for me.
