  • July 16, 2025, 01:26:46 AM
Author Topic: Extending ESC Wires  (Read 1817 times)
Extending ESC Wires
« on: March 23, 2016, 09:24:35 PM »
I've got an ESC I shortened the wires on for a certain plane. Now I want to use it where I need longer wires to the arming plug and battery. I've got the wire but, does anyone sell a straight coupler you can solder on or should I just use brass tubing?
Re: Extending ESC Wires
« Reply #1 on: March 23, 2016, 10:33:13 PM »
You might want to talk to a bonifide ESC guy, but I have read splicing  by whatever means to the motor leads on an ESC is a no no
« Reply #2 on: March 24, 2016, 12:36:30 AM »
It's more that you don't want to extend the wires between battery and ESC by too much, because it causes electrical difficulties.  If he's already shortened the wires, bringing them back to the original length shouldn't be a problem.
Make sure to do a workmanlike job, and use heat-shrink tubing over any connections.
Online Igor Burger
« Reply #3 on: March 24, 2016, 01:26:28 AM »
« Reply #4 on: March 24, 2016, 12:13:17 PM »
Thanks Igor, I have used that method before. I think this time, after stuffing the ends together, I will wrap it with thin copper wire to consolidate the bundle.
Is there any problem having the two battery leads be different lengths?
« Reply #5 on: March 24, 2016, 12:54:19 PM »
Not to my knowledge.  It's the overall length of the wire that's an issue.
It's probably a good idea to keep the two battery leads together as much as possible -- this is much more important in an RC ship.
