  • July 08, 2025, 02:11:53 PM
Author Topic: Eurochamps 2011  (Read 1086 times)
Offline Peter Germann
Eurochamps 2011
« on: July 29, 2011, 06:27:04 AM »
Today, July 29 2011  Igor Burger won the 2011 F2B European Championships in Czestochova, Poland.
Congratulations, Igor
Peter Germann
Offline John Hammonds
Re: Eurochamps 2011
« Reply #1 on: July 29, 2011, 07:22:52 AM »
WTG. It obviously flew as good as it looks, Congrats Igor.
[EDIT] I notice the results sheet on the web page does not show flight 3. Has he definitely won?  H^^ [/EDIT]
TTFN
John.
« Last Edit: July 29, 2011, 08:26:35 AM by John Hammonds »
BMFA 165249
Online Dennis Adamisin
Re: Eurochamps 2011
« Reply #2 on: July 29, 2011, 10:16:22 AM »
Wow that is GREAT news!  Igor is one of our pioneers, it is especially gratifying to learn of his sucess.
CONGRATS Igor!!!
Offline Dean Pappas
Re: Eurochamps 2011
« Reply #3 on: July 29, 2011, 10:52:00 AM »
Bravo!
Dean Pappas
Online Howard Rush
Re: Eurochamps 2011
« Reply #4 on: July 29, 2011, 03:57:02 PM »
Igor is King:
Offline John Cralley
Re: Eurochamps 2011
« Reply #5 on: July 30, 2011, 08:39:14 AM »
Wow!! Way to go Igor!!
Igor's win and his previous high places in contests with his electric powered models is sure to spur a movement toward electric (the 21st century power for control line) competition models. All that indoor winter practice may just have paid off for Igor - plus his innovative design a superb building skills.
Congratulations Igor!! H^^
John Cralley
AMA 52183
Central Illinois
Offline Igor Burger
Re: Eurochamps 2011
« Reply #6 on: August 02, 2011, 02:40:14 AM »
Thank you all guys ... and girls :- ))))
I will update more details soon.
So far I can tell we had 4 electric models. 1 from Slovakia, 2 from Czech and 1 from Spain (If I do not count backup model of Richie K.). I hope I did not miss some ... using sound generator or something like that :-P
Offline Igor Burger
Re: Eurochamps 2011
« Reply #7 on: August 03, 2011, 03:02:49 AM »
So as I promised, here is list of electro flyers on EC:
Igor Burger: I needed to add some nose weight so I decided to replace my AXI 2826/13 by heavier Scorpion 3026/710 which has aproximately the same properties, just little heavier and theu better absorbing heat, I use 3b carbon prop 11x5 at 11000, large lipo battery 6s 2600, Jeti spin 66 and active regulation. ... I would say it worked well  ;D
Richie Kornmeier: he used his ST60 model, but his B model was electric, I am not absolutely sure with his setup, but for sure he had large 3bl wood prop 13xsomething, motor orbit XXXX and battery 6s 2600 all on constant RPM setup
Juro Vejmola: Axi 2826/13 APC 12x6 lipo, spin 66, active regulation ... sometimes doing strange noise like cats hunting mouses  LL~ , but otherwise well flying when set it VERY conservatively (I wold say almost switched off  VD~ )
Jan Skrabalek: Axi 2826/13, APC 12x6, lipo, spin 66, constant RPM - well and safe working setup
Alberto Soliera: ... I hope he will add his details himself :- ))))))
Michal Meisl (jun): Axi 2826/13 APC 12x6 lipo, spin 66, active regulation, he did few mistakes, like changed regulation without properly set parameters and so lost flight ... just junior withou coach  HB~>
Peter Kapuscinsky: used his old model with 6s A123 setup with AXI 2826/13, Spin 66 and APC 12x6 at constant RPM ... he was not prepared well, because he replaced another flyer just 2 weeks before contest and he did not have enough time to prepare himsef
results availabe here: http://www.controlline-ech2011.pl/images/stories/pdf/results/F2B_aerobatic_individual_results.pdf
Offline Alberto Solera
Re: Eurochamps 2011
« Reply #8 on: August 03, 2011, 07:01:54 AM »
Seems you also won the timers builder championship  :)
My system is orbit 20-12, cc ice 50, nanotech 4s 3300 and timer from jpaeromodels (v2) with constant rpm (waiting for v3  ;D). I used a home made carbon fiber copy of the apc 13-4,5.
Your active control worked really well, good job!
bye  :)
