  • June 24, 2025, 05:28:05 PM
Author Topic: Charger Cuts Foam  (Read 4589 times)
Charger Cuts Foam
« on: November 22, 2015, 06:46:34 PM »
Still slowly but surely setting up to cut foam. Anyone cutting foam with their battery charger? Just found my icharger 306B has a foam setting, just wondering if it works good.
Offline Curare
Re: Charger Cuts Foam
« Reply #1 on: November 23, 2015, 08:17:21 PM »
I use my Powerlab 8 to cut my cores. I adjust the amperage depending on what I'm cutting and the length of my bow.
Do a couple of cuts to get the temp right, then have at it.
Greg Kowalski
AUS 36694
Offline Ken Burdick
« Reply #2 on: November 24, 2015, 11:14:25 AM »
a variac is a good tool. Another that is a little less safe but very effective and inexpensive is a light dimmer.
Old flying lines can be used in a pinch, but make a good bow with ni-chrome wire.
For double tapers, a simple fixture made from a 40" bow with a knuckle joint can be made. The swing is side to side and up and down. Fix it to the wall and adjust your bottom plate the foam sits on up and down to the right height.
This is a Combat fliers friend in the shop for years.
K
Offline REX1945
  • AMA 19945
« Reply #3 on: December 07, 2015, 06:13:14 PM »
MM,
I use an EKI full wave speed controller.  You can buy the kit and
assemble it yourself ($ 14.49 ).  It can handle any length of wire, since
it has a potentiometer. it is, of course, a lot less money than a variac.
Longer wire, more voltage for the same temperature.
EKI link :  https://abra-electronics.com/educational-kits/motor-and-stepper-motor-kits/eki-2062-full-wave-motor-speed-control-kit-eki-2062.html?sl=en
These kits were developed as electronics education projects : Potentiometer, 2 capacitors, resistor, 2 diodes, 2 neon bulbs, 2 SCRs, slide switch, outlet, line cord.  Also includes the circuit board. You should make an enclosure for safe operation.
In order to compensate for the expansion of the wire ( min is 48" long), I put a screen door spring at on end of the wire so that the reduction in tension
is minimal.
Rex
« Reply #4 on: December 09, 2015, 10:03:39 PM »
Build a kit? my charger can do it. My main problem is I don't know where to buy foam and nobody seems to want to give up their source.
« Reply #5 on: December 09, 2015, 11:20:41 PM »
 Look for a place that sells "refractory materials" and ask for 1 pound virgin foam.  Bob Hunt can tell you where to get it in your neighborhood.
« Reply #6 on: December 11, 2015, 10:50:09 AM »
Bob gets his foam in a block as big as a voltswagon. I should probably just buy from him if he'll sell the blanks.
Offline Ken Burdick
« Reply #7 on: December 15, 2015, 03:23:56 PM »
you can buy practice foam from the Home Depot.
Offline jfv
« Reply #8 on: December 16, 2015, 10:46:54 AM »
Your a Jersey man.  Here's where I get my foam for wings.  Ask for 1 pound virgin foam.  I get blocks cut  2", 3" and 4" thick.  Each block measures 38" x 48 1/2".  I go pick it up, so no shipping cost except for my gas and time.  I usually buy 8 to 10 blocks at a time.  Not cheap but I think they are reasonable.
Foam Pack Industries
72 Fadden Road
Springfield, NJ
973-376-3700
Jim Vigani
Offline Ken Burdick
« Reply #9 on: December 16, 2015, 11:45:19 AM »
the quick and simple controller is a light dimmer. Other than having 110v ac at the output, it works great.
Offline REX1945
  • AMA 19945
« Reply #10 on: December 17, 2015, 07:58:53 AM »
Motorman,
     It's really a dilemma with me; to buy a kit or to buy an ARF. Thanks to folks responding your post, I know that
the light dimmer is a true option and that it is CHEAPER than the EKI kit. So, if the ARF is cheaper (and probably more
robust), the ARF is the only option.
    Fate was with me yesterday as my trusty EKI unit gave up the ghost yesterday and I actually went to HD and bought
a $ 4.95 light dimmer.
     I always have an incandescent light bulb in parallel with the nichrome wire so that I can respond to changes
in voltage of the supply output. When the air compressor started, the voltage dropped and the wire cooled without
returning to temp when the compressor stopped. This probably caused by the weird properties of either the nichrome
or the control that make the circuit resistance an inverse function of wire temp.
     However you power the cutter, I suggest you monitor voltage across the wire to be able to respond to changes. I'm
sure a refrigerator starting on the circuit could do the same thing.
Offline Fredvon4
  • Central Texas
« Reply #11 on: December 17, 2015, 02:14:55 PM »
I would be concerned with the shop wiring or the compressor start capacitor if-- as the compressor is running--- the shop voltage drop was that noticeable on a hot wire bow
I have a very complicated primary supply to the house and three external shops (2 of which are on a separate meter but common transformer)
If the house AC soft starts or the air compressor kick on, or I fire up the high amp table saw and dust collector I can sag the AC voltage only during the start time and then back to full AC voltage
Then again my son is a master electrician who designed all my shop service and used the proper sized wiring and breaker panels.
If you think your wiring is proper I would suspect the compressor start capacitor is weak and need replacing
Fred von Gortler IV
Offline Phil Krankowski
« Reply #12 on: December 18, 2015, 04:08:54 PM »
Motorman,
Start popping panels, checking wire size, and tighten everything.  It is pretty amazing how loose wire fittings get after a few years, even properly sized stuff will heat up enough to loosen!  (even at the outlets)
If there is under size wire, then pull another circuit.  Either remove the old circuit, cut it back abandoned, or breaker it for the draw it is allowed to take and use the circuit accordingly.
Other than the mains this is an easy job that is safe to do after turning off the mains.
Phil
