  • June 28, 2025, 11:48:54 PM
Author Topic: ESC - what is the latest and greats for 2016  (Read 6589 times)
« on: December 23, 2015, 07:51:36 AM »
Guys,
I keep going between ECL and glow so I haven't kept up with the latest thinking on ESC controllers that are now being used. I have been using the old Castle Phoenix 35 & 45 and the ICE 50. They all still work for my applications but would like to know what is currently being used.
Best,    DennisT
Online Howard Rush
Re: ESC - what is the latest and greats for 2016
« Reply #1 on: December 23, 2015, 11:22:49 AM »
 Jeti Spin 66, but I wonder if there's another with as quick or quicker response to input.
« Reply #2 on: December 24, 2015, 08:38:01 AM »
Does the Jeti Spin have the CL brake? Who is the vendor for the US sales?
Merry Christmas Happy Holidays,
DennisT
Offline Crist Rigotti
« Reply #3 on: December 24, 2015, 08:40:00 AM »
Use a Jeti Spin with Igor's Active Timer.
Online Howard Rush
« Reply #4 on: December 24, 2015, 09:27:45 AM »
Yes.  You get them directly from Igor.
Offline Carl Cisneros
« Reply #5 on: December 24, 2015, 10:08:40 AM »
you can also get the  Jetti ESC's here in the states in Florida from Esprit Tech
http://www.espritmodel.com/
Carl
Carl R Cisneros, Dist IV
Control Line RB
« Reply #6 on: December 24, 2015, 10:20:22 AM »
Carl
Aren't those ESC Spin Pros?  The good ones are only Spins.
Offline Jeff Traxler
  • T-Bone
« Reply #7 on: December 25, 2015, 08:38:16 AM »
Yes Virginia there is a Santa Claus...........
« Reply #8 on: December 25, 2015, 12:28:44 PM »
so, what does it do that others don't do?
Offline Russell Bond
  • Bandolero
« Reply #9 on: December 25, 2015, 06:21:56 PM »
Works with Igor's timer the best.......... :)
Bandolero
Offline Jason Greer
« Reply #10 on: December 27, 2015, 07:52:53 PM »
The spin esc's will change rpm very fast while in governor mode. Most other esc's do not respond fast enough while in governor mode. This is only a concern when using an active timer like Igor's. If the response is too slow, then the power increase/decrease will not happen at the correct points in the maneuvers.
El Dorado, AR
AMA 518858
  • Bandolero
« Reply #11 on: December 27, 2015, 08:00:13 PM »
Yes and you have to use the old Spin 66, not the new Spin 66 Pro.
Igor gets Spin to make the old ESCs to order. (10 at a time I believe.)
Bandolero
Online Howard Rush
« Reply #12 on: December 27, 2015, 08:24:32 PM »
Looks like you've been good.  I got some carbon, but it's not the right form for landing gear or anything.
Offline Fred Underwood
« Reply #13 on: December 27, 2015, 08:58:30 PM »
Sounds like your carbon was in lump form.  A coal burner could make it useful.
Fred
352575
Offline Igor Burger
« Reply #14 on: January 13, 2016, 11:04:14 PM »
Jeff, do not you have reverted connector on the timer? That red point on connector must be oriented to orange wire of ESC lead.
  • T-Bone
« Reply #15 on: January 14, 2016, 09:00:24 AM »
Thanx Igor,I will take a look at it.That is the way I received it.Not quite ready to install.
Offline Igor Burger
« Reply #16 on: January 14, 2016, 09:55:27 AM »
In case you do not have description, you can download it here:
http://maxbee.net/downloads/downloads.htm
the first link on top
Tags: ESC  controller
