  • July 17, 2025, 08:17:34 AM
Author Topic: ESC settings and heat................  (Read 901 times)
Offline Russell Bond
  • Bandolero
« on: December 14, 2013, 03:29:13 AM »
With the Castle Ice50, is it better to run at approx 80% or approx 70%?
In other words, if you have a choice of running higher up in the percentages than lower, which way generates less heat in the ESC?
I'm running at about 74% at the moment, but I have a prop to try that will be about 70% on the ESC.
Another prop to try means I'll be 80% or a bit over and in our heat in Australia, I would like to run as cool as possible.
Bandolero
  • Bandolero
Re: ESC settings and heat................
« Reply #1 on: December 14, 2013, 02:14:54 PM »
I forgot to mention that I'm running Set RPM. ☺
Bandolero
Offline Crist Rigotti
« Reply #2 on: December 14, 2013, 03:25:21 PM »
Russell,
I don't think it makes much difference in the real world.  I say go fly and have fun.
Offline William DeMauro
« Reply #3 on: December 14, 2013, 03:26:11 PM »
The lower the percentage the more heat you will generate. I believe around 80-85% is about the best but 74% should be within acceptable ranges. If I remember right these figures are on the Castle website. If I'm wrong I apologize in advance.
AMA 98010
« Reply #4 on: December 15, 2013, 09:42:59 AM »
If you are at 100% throttle then there are no heat spikes for switchin - unfortunately there is no governing either!  I like to shoot for 70% to 75% throttle to maximize the headroom for governing - but that is also about the worst place you can be for heat spikes due to switching.
Can't put my finger on it, but I believe Castle discourages high PWM because the ESC can go hotter, however low PWM settings makes the motor run hotter.
I agree with Crist - choose your best settings for flight performance, then do all you can to promote ESC cooling.
