  • June 14, 2025, 01:26:04 PM
Author Topic: Simple Motor question  (Read 720 times)
Offline Andrew Borgogna
  • Andy
« on: August 13, 2011, 07:12:42 AM »
Most if not all motors come with a collet and set screw that fits the shaft size.  I have yet to figure out the use of the collet.  The are typically made of brass and have a Allen screw for locking them down.  Can someone tell me what they are used for?  ???
Andy
Andrew B. Borgogna
Offline bob branch
Re: Simple Motor question
« Reply #1 on: August 13, 2011, 07:40:45 AM »
Andy
This type of prop shaft is used when the motor is mounted to a nose mount on most motors. In this type of mount the mount is placed in front of the motor. The motor is mounted with bolts thru the mount and the motor shaft extends forwards thru the mount. The collet is then placed on the motor shaft and secured, with the allen screw in this types case. Unfortunately, many of us have not had much luck with set screw retained collets. They tend to spin off. A more secure type uses a pinch connection. When the prop is tightened the prop backplate which is tapered internally tightens down on usually 3 jaws that go over the motor shaft and secure the collet to the shaft. One caviat with these is that is one ever does spin loose it will not for some reason be reusable and a new one must be used. Once they spin off once the seem to keep doing it. Having said that while I have had many of the set screw ones loosen, even with multiple set screws and flats ground into the motor shaft, I have never had a clamp down one come loose. They must be sized by the way to the shaft. Pretty much all are metric sizing.
bob branch
  • Andy
« Reply #2 on: August 13, 2011, 12:47:28 PM »
Bob
Here is a picture of the part I am talking about.  I know of the part that has two screws in it for attaching props with O-Ring I was not sure if that's what you were talking about.  This is a different part, this looks like something to retain wheels on wire landing gear.
Andy
Andrew B. Borgogna
Offline Dean Pappas
« Reply #3 on: August 13, 2011, 12:52:28 PM »
Hello Andy,
On some motors, like the AXI ...
If you mean the oversized wheel collar, then that is used when firewall mounting the motor.
If the prop is mounted to the rotating bell, then it is actually possible to pull the bell and shaft out of the fixed portion of the motor unless the big collar and "C" ring are placed on the shaft that protrudes from the rear of the motor. The C-ring, if provided, is not enough on its own.
When front-mounting the motor this is not an issue.
I hope I understood your question properly,
   Dean
Dean Pappas
  • Andy
« Reply #4 on: August 14, 2011, 11:29:12 AM »
Thanks Dean that explains it.  I have four firewall mounted motors and none of them have that part installed and there is no way to install them in any of the planes.  ~^ Ug!  I guess I will hope for the best and keep it in mind for future projects.  Again thanks
Andy
Andrew B. Borgogna
