  • June 24, 2025, 03:57:18 PM
Author Topic: Brodak Flite Streak Conversion kits  (Read 1990 times)
Offline Phillip Kenney
« on: October 18, 2022, 07:47:14 AM »
I have an original Top flite Flite Strea kkit that I would like to set up for Electric power. Has anybody used either of Brodak's conversion kits on an original
 Top FLite kit?
Offline Douglas Bykoff
Re: Brodak Flite Streak Conversion kits
« Reply #1 on: October 19, 2022, 05:51:33 PM »
I built several Lighting Streak models and converted them to electric with very good results.
Motor: Turnigy SK3 2836 1040Kv
Esc: Yep 30A
Battery: Tattu 4s 1300mha
Prop: APC 9x5 (glow)
Timer: Fiorotti's passive timer
Model yellow
Motor: Turnigy SK3 3530 1340Kv
Esc: Yep 30A (better use 40A)
Battery: Gens Ace 3s 2200mha
Prop: MHS 10x5 electric
Timer: self made 2 speed 433mhz Remote
« Last Edit: October 19, 2022, 06:53:32 PM by Douglas Bykoff »
Offline John Rist
« Reply #2 on: October 19, 2022, 07:04:35 PM »
I used an Oki Air printed motor mount to convert a 1960 vintage Flight Streak. Worked pretty good.  I had to cut into the leading edge of the wing and did some internal reinforcement.
https://okieair.com/shop/ols/products/printed-motor-mount/v/PRINT-MNT-PRF-FSL-BAD-ASS-282
