  • July 09, 2025, 08:41:37 PM
Author Topic: ESC comparisons  (Read 1231 times)
ESC comparisons
« on: February 24, 2013, 12:45:25 PM »
OK, here's where I show my complete ignorance of this stuff. I have read that the Castle Creations Phoenix ICE2 HV60 is a replacement for the old Phoenix 60 ESC. What's the difference? I've read the specs, but I don't really understand the difference.
OK, I'm ready to be educated and informed.
Re: ESC comparisons
« Reply #1 on: February 24, 2013, 12:55:40 PM »
Just looking at the specifications, the new one will withstand twice the voltage.  Hopefully it has better data logging.
And it definitely has a nicer looking heat sink.
Offline Robert-Jan
Re: ESC comparisons
« Reply #2 on: February 24, 2013, 01:25:15 PM »
no BEC ?
Offline Dean Pappas
Re: ESC comparisons
« Reply #3 on: February 24, 2013, 01:32:34 PM »
Hi Randy,
The "HV" series are intended for higher voltage systems like 8S ~ 12S batteries. They have opto-isolated inputs and no BEC.
I don't think you want one for Stunt.
  Dean P.
Dean Pappas
Offline Andrew Borgogna
  • Andy
Re: ESC comparisons
« Reply #4 on: February 24, 2013, 05:52:52 PM »
Dean is correct, these types of ESCs are intended for very large scale R/C plane where they have several batteries tied in series.  The reason they don't have a BEC is because for safety they put the receiver and servos on a separate battery, with a battery backup system on the primary battery, at least that was how I did it back in the day.  I really can't see any application for these ESCs in control line.
Andy
Andrew B. Borgogna
Re: ESC comparisons
« Reply #5 on: February 25, 2013, 09:17:50 AM »
Thanks, guys. I suspect I'll just go with the ICE75 but am still scanning around. I had a Phoenix 60, but it turned out to be defective and they are no longer available (apparently).
Offline Dean Pappas
Re: ESC comparisons
« Reply #6 on: February 25, 2013, 09:56:07 AM »
There is a whole new series coming to replace the Phoenixes.
Dean P.
Dean Pappas
Re: ESC comparisons
« Reply #7 on: February 25, 2013, 12:51:45 PM »
That would be nice. I'm still learning all this stuff. Guess I should have paid more attention in electronics classes.   LL~
Re: ESC comparisons
« Reply #8 on: February 25, 2013, 01:17:27 PM »
Just remember the basics Randy:  Electronic components are made of smoke which can, through various expensive processes, be made into solid matter.  This smoke is packed inside of little plastic packages, which are then soldered to a board.
If you let the smoke out, things don't work any more.
What else do you need to know?
Re: ESC comparisons
« Reply #9 on: February 25, 2013, 02:49:40 PM »
Gee, thanks, Tim.
Re: ESC comparisons
« Reply #10 on: February 25, 2013, 03:32:47 PM »
He probably wants to know how to keep that expensive smoke catpured inside the plastic thingies,, duh!!
Online Bob Hudak
Re: ESC comparisons
« Reply #11 on: February 25, 2013, 07:15:12 PM »
Fire is a good troubleshooting tool And smoke is a visible indicator of trouble.
350838
