  • June 16, 2025, 04:10:52 PM
Author Topic: My new competition stunter the Newtron  (Read 3013 times)
Offline Keith Renecle
« on: July 24, 2012, 10:03:08 AM »
Hi All,
I started planning this design last year as a design for electric power from the start. It had to be an all take-apart model as I need to take it with me to overseas competitions. My target weight was 1650 grams (58.2 oz) but unfortunately I did not manage to achieve this and it came out a bit heavier and that necessitated a larger capacity battery. So now it weighs 1730 grams or 61 oz. I have test flown it and it flies very well at this weight so maybe it's not so bad after all.
It's powered by an E-Max 2826 with a 60 amp ZTW esc and 4-cell Nanotech 3000 mAh lipo. The timer is my KR ver. 2 governor timer and I'm turning a 12 x 6,5 APC wide blade prop from Dennis. I've also tried the standard old thin blade APC 12 x 6 but the extra amount of thrust from the wide blade is awesome so I'll most likely stick to these props.
I'm using one of Igor's laminar flow airfoils plus and air-foiled thick stab. From take-off it was groovy and that is what I was trying to achieve. It has a very sharp corner and still locks in nicely and tracks on rails, so right now I am rather pleased with the way it flies. The paint job is very basic and a bit flat at the moment so maybe I'll spray a bit of strategic clear something or other on it. This is the great thing about e-power.......you can fly before the finish is actually completely done!
The name "Newtron"......o.k. my spelling is not too good?? No, it's actually a new version of what I learned from the Electron that I've been flying since 2008, so it's a New ElecTron. As some of you know, I do have fun playing around with words! I spent a week flying at sea level with Percy Attfield to see how it worked out before we go to Bulgaria for the world champs at the end of August. It does need a little more trimming but so far it feels great. Now I just need to trim the pilot!
Keith R
Keith R
Online Crist Rigotti
Re: My new competition stunter the Newtron
« Reply #1 on: July 24, 2012, 11:18:23 AM »
Wow, I like the paint scheme!  Nice job Keith.
« Reply #2 on: July 24, 2012, 11:21:29 AM »
What Crist said!
Also I like the cross sections in the nose - nice job with the cheek cowls and how they blend in by the wing.
KEEP PRACTICING!
« Reply #3 on: July 24, 2012, 12:02:49 PM »
Thanks Crist & Dennis, It's a very basic color scheme but it looks neat. The cheek cowls are functional. The inner one is held on with a single screw and covers the esc. The outer one clips on with a simple pull clip like a canopy clip and this gives access to the battery and timer. It's really easy to get the battery in and out. I'll take a few close-up pics tomorrow. Each cowl weighs 10 grams (painted) so they are not very heavy.
One other thing is that the flap and elevator hinges are kite cloth, or ripstop nylon. I make the wing traling edge and the flap leading edge in 2 halves and the cloth extends right across the joint. I add plastic hinges on each end just to make sure that there is no slackness in the hinge line. It's a bit more work but seals the hing line without adding tape.
Keith R
Keith R
« Reply #4 on: July 24, 2012, 02:20:47 PM »
Nice Keith.....the only other thing to do is to give this to Loren at the worlds so he can bring it back for me!  LL~ LL~ LL~
I have been pondering that idea of a full length hinge for a while - I think you have cracked it with the addition of hinges at each end.........well thought out!!!
« Last Edit: July 24, 2012, 05:50:01 PM by Wynn Robins »
Online Howard Rush
« Reply #5 on: July 24, 2012, 08:50:43 PM »
I thought Newtron was a synthetic fabric made from Newts.
« Reply #6 on: July 24, 2012, 09:43:20 PM »
Howard you are thinking of Newtyester
Offline Allan Perret
  • Proverbs
« Reply #7 on: July 24, 2012, 09:55:14 PM »
Nice, I like the clean simple lines.   61 is light for a take apart..
Lucky # 7   ?
The prop you are liking, pusher or puller ?
What is the wing's span and area ?
Not understanding you continuous hinges, have any pictures of that part of the construction ?
Good luck in Bulgaria..
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #8 on: July 24, 2012, 10:26:31 PM »
Maybe that's what I used for the hinges??
Keith R
Offline Andrew Borgogna
  • Andy
« Reply #9 on: July 24, 2012, 10:55:58 PM »
Nice job Keith, I was starting to worry that you wouldn't be ready in time for the Worlds.  I would be curious to know what your RPM is set to and what you have the gain set to.  I fly a 61 ounce plane with a Hacker A30-10XL using the same prop at 8100 RPM an can get the pattern done with 2600mha battery and still have 20% left in the battery.  But then again I do not fly the pattern like you do, maybe someday.....  Anyway looks great and wish you the best at the Worlds. :)
Andy
Andrew B. Borgogna
« Reply #10 on: July 24, 2012, 11:31:29 PM »
Hi Andy, I am still worrying!! I was way behind on my schedule...as always. I'm setting the rpm to around 8600 and I was hoping to use a 2700 Thunder Power Pro-lite 4 cell pack, but I'm consuming 2200 mAh, so that would be pushing it a bit. Loren Nell that flies with Wynn in New Zealand is using the same motor with the 3000 mAh Nanotech and has some reserve. What line length are you using?
Allan, the number was just a number that I liked at the time.....no superstition or anything. The wingspan is 58 inches and the area is around 670 squares. The 12 x 6.5 EW is the pusher from Dennis. I intended to take lots of pics when I was building but got way behind with time as I said above, so I only took a few unfortunately. I was also busking my way and trying a few new techniques. If you don't mind seeing the messy workshop, here are a few pics (Wynn can ask Loren about my workshop......it's usually a disaster area!)
Keith R
« Reply #11 on: July 25, 2012, 10:24:28 AM »
Keith, is 8600 RPM what you use at your 5000' elevation?  How about at sea level?  Most of the feedback I have received indicates 8200-8400 RPM works pretty well, you are one of the only people I know who flies at either extreme of elevation.  Hmmm, what elevation is the WC site in Bulgaria?
...and I still have 12x6.5 Wide Pushers for sale! $6 each plus postage (hint hint)  PM me if you are interested.
  • Andy
« Reply #12 on: July 25, 2012, 03:38:55 PM »
I think you nailed it Dennis, I fly at sea level and my tach bounces back a forth between 8100 and 8200.  Keith I fly on 59' eyelet to eyelet lines and I have good line tention everywhere.  But again I don't fly at 5000 feet, its just like when I fly at VSC at 3000 feet and have to add nitro to my normal mix to get decent performance.  It would be interesting to know what the altitude is in Bulgaria, you may have to drops the revs a bit when you get there.
Andy
Andrew B. Borgogna
« Reply #13 on: July 25, 2012, 04:29:24 PM »
Looking good, Keith!  I like the construction and your system of enclosing the electronics.
Best wishes at the WC!
Offline ash
« Reply #14 on: July 25, 2012, 05:33:52 PM »
Ha! One of us is a mind reader, Keith. First the take-apart system you detailed a while ago is just like mine and now your foam wing construction is also just like mine. I think I must be the mind reader and you the talent as you've built yours and I'm still dragging the chain :D
« Reply #15 on: July 26, 2012, 12:09:27 AM »
Thanks Bill, it is quite neat and simple to use. The "plumbing" worked out very well so all in all, I'm quite happy with it so far. I'm also very happy that it grooves so well without the usual wiggles that I normally have to sort out.
Keith R
« Reply #16 on: July 26, 2012, 12:15:19 AM »
Hi Ash, I have my spies over there, so you need to hide stuff! The foam and balsa wing with cut-outs for the ribs saved a lot of weight. Each half with paint and all weighs around 210 grams. This is quite good for a take-apart wing. The fuselage nose section put on a bit more weight than I planned so this could use a bit more work. I used white wood glue to glue the balsa onto the wings by the way. I let it dry on both sides and ironed it on. The upper and lower fuselage decking is made the same way.
Keith R
Offline Igor Burger
« Reply #17 on: July 26, 2012, 01:22:55 AM »
My maps show 212 m over sea ... I do not know if black or atlantic, but looks like proper altitude for newzitrons ;D
« Reply #18 on: July 26, 2012, 11:34:52 AM »
Hi Bob,
Thanks so much for the nice comments and I also appreciate the history on your experience with this type of construction. I was aware of the weaknesses as well and this was another reason for using a poly-tissue called Dacmat. It's just as good (or bad) as Polyspan but is slightly thicker at 35 grams per sq. meter instead of 25 like Polyspan. Plastic film would have been too weak. Maybe "money-coat" would work. I seem to hit a wall of around 250~260 grams per wing panel with all of my other methods for the same size, so this weight of 210 grams is a bonus. Even the Yatsenko Shark wings are similar. I did some very hard corners down at sea level in some strong gusty wind, and the wings seemed o.k. I suppose that time will tell, as long as they don't let go in my qualifying rounds in Bulgaria..........!
If I did manage to achieve the target weight of 58 oz. then I was not too worried about the wing loading. The fuselage front section came out heavier and most of the extra weight was there. I seem to remember you saying something about models can be real light but not too weak, and as I was building the snout, it felt a little flimsy here and there, so of course I just kept adding stuff. It flies really well in my opinion so I should enjoy it in Bulgaria. I'll be flying plenty during these few weeks before we go so I'm hoping that I can just trim a few more little things and then it should be fine.
On my timer story, I would love you to try it!! For something that started out as just something a little better for beginners and sport fliers to get into e-stunt, it has developed into a viable competition system without breaking the bank. I've also made it a lot better from the feedback from some good guys and now I feel so good when someone like Dennis Adamisin says that it works well. It would be great therefore to add your feedback to the list. I look forward to this, so thanks a lot!
Keith R
