  • August 04, 2025, 04:13:02 AM
Author Topic: Oooopps again, at Baton Rouge  (Read 1307 times)
Offline Ty Marcucci
« on: October 27, 2012, 11:20:29 AM »
There I was, at 10,000 feet and two Zeros on my tail when all of a sudden my motor takes off and heads for the pits. Missed two planes by a thin margin. Plane did a fancy falling leaf, but landed on the nose at the last five feet. A nameless person, knowing nothing about electric motors, picked it up, held it and tried to turn the prop and stated, "the bearings are frozen". Ha. He knew nothing of out runners.
« Last Edit: July 17, 2017, 12:52:03 PM by Ty Marcucci »
Ty Marcucci
Offline Allan Perret
  • Proverbs
Re: Oooopps again, at Baton Rouge
« Reply #1 on: October 27, 2012, 01:55:08 PM »
Get a G10 mount from Bob Hunt and use Locktite.
Allan Perret
AMA 302406
Slidell, Louisiana
Offline Andrew Borgogna
  • Andy
« Reply #2 on: October 27, 2012, 02:23:45 PM »
Blue Locktite is what I use.  I also use blind nuts or self locking nuts, I prefer them to Locktite.
Andy
Andrew B. Borgogna
Offline William DeMauro
« Reply #3 on: October 27, 2012, 02:48:31 PM »
Ty,i
  On my SV11, I used a double X mount. I put the second behind the firewall and put the screws through it creating a sandwich effect. I used locking nuts on the back.If your motor is front mounted(after re reading this ,I suspect that it is) the above does not apply,then I think the locktite trick mentioned above is your best bet.Another trick that I have used( when I did not have locktite is a little white glue(not excessive) on the threads. It holds well and breaks free when you need to get it off. It seems to hold up well enough to heat and vibrations for our purposes, at least it has for me.
AMA 98010
Offline Dave Denison
« Reply #4 on: October 27, 2012, 03:08:36 PM »
Ty.
Well written, but.........remember the song--  "Three little words".....maintenance, maintenance, maintenance.    Electrics do have some vibration.
What we need is miniature safety wire and one A&E personnel in the family.
Regards.
ama41041
ama 41041
Offline Steve Fitton
« Reply #5 on: October 27, 2012, 09:30:27 PM »
It seems a tad excessive to do maintence after only one flight. I use star washers instead of the split ring type.  I still find it hard to understand how they all came loose after only one flight. There was no vibration or very little while on the ground. But who knows, once it got in the air, no one holding it to dampen any vibs, it just let loose.
As to the Bob Hunt mount, I have 6 of them and have applied one to my Magnum plus. Hope to get it back in the air soon.
Meanwhile I have taken a break from building planes  and am doing a solid scale model of a Gearing class tin can, the USS Newman K. Perry, DD883. My first tin can, not counting the two I was TDY on. . No weight worries here, no fuel, no batteries, just paint it, glue it, put it on the mantle. USS Iowa next. Only this one floats. H^^
The way things are going, you better have some way of raising that Iowa model after it sinks..... HB~>
Offline Dean Pappas
« Reply #6 on: October 29, 2012, 10:48:10 AM »
Hello Ty,
Screw crush could have been the cuprit. So could flexibility in the fuse: if the front of the fuse had a natural resonance near the running RPM or the running commutation (cogging) frequency then things will loosen amazingly quickly.
The G-10 plate Hunt sells is a great start, but there is a limit as to how much weight can be saved in the front of an E-Stunter.
Let us know what solves the problem, though.
take care,
   Dean
Dean Pappas
« Reply #7 on: October 29, 2012, 12:07:08 PM »
Screw crush could have been the culprit.
Sounds like a form of infatuation with base motives.
Offline Dan Bregar
  • Field Marshall
« Reply #8 on: October 29, 2012, 05:49:07 PM »
Howard, your killin me ! LL~
AMA 33676
