  • June 27, 2025, 03:01:22 PM
Author Topic: Electric powered Stuntmaster  (Read 1280 times)
Offline Michael Boucher
« on: July 07, 2010, 10:07:56 AM »
Hi, I was wondering what would be a good electric set up for a profile Stuntmaster by Blackhawk models? Thanks, Mike
AMA 59633
Re: Electric powered Stuntmaster
« Reply #1 on: July 07, 2010, 11:19:07 AM »
Hi Michael,
While I know NOTHING AT ALL about electrics, I can give you ideas about the Dtunmaster that *might* help making the decision.
Mine is scratch built, with no real care given to weight, but it isn't a *porker* by any means.  (mainly because all my wood is 4-6lbs).  It flies MUCH better than it should with with a McCoy 35RH or a Veco 35 stunt.  I use both since they are direct swaps, and various 10-5 props.  Several people have flown it and will concur.
SO!  Something along the lines of that *horsepower rating* is what I would suggest.
(probably no help...... )
Big Bear
« Reply #2 on: July 10, 2010, 04:59:01 AM »
Brodak part #BH-1833 is the complete power system from the electric Super Clown. This would be a great match to your Giant Stunt Master project.
One good thing about the Brodak system is that it uses thin battery packs - build a pocket into the wing and slip the pack into it for a nice clean installation.  Also you can let the pack stick ou some if you need to for CG adjustment.
« Reply #3 on: July 10, 2010, 07:58:43 AM »
Hi Dennis, Thank you very much for this information, I appreciate it.  H^^
AMA 59633
