  • July 08, 2025, 03:28:09 AM
Author Topic: Electric Peacemaker Plus  (Read 782 times)
Offline jjorgensen
« on: February 12, 2011, 03:39:35 PM »
Here it is in paint. Behr indoor latex. I have to let it dry for about a month before I can clear coat so it looks a little dull at this point
Jim Jorgensen
Re: Electric Peacemaker Plus
« Reply #1 on: February 12, 2011, 06:33:26 PM »
Looking GOOD JJ!
Can you share what you did to prep the surface, partucularly anything special you did to ready for the latex colors?   I presume you sprayed the color coats?  ANy problems with adhesion or pulling up paint when you started masking?  What kind of top cote are you planning to bring up the gloss?  Are the paints heavy?
I am working on a warbird that would really benefit from a matte finish, so your efforts here could be directly applicable to my project.
Looking forward to your flight tests too.
Offline jjorgensen
« Reply #2 on: February 12, 2011, 08:51:58 PM »
Thanks Dennis. I applied monocote over the open bays, then covered everything with silkspan. I used minwax to apply the silkspan. Then a couple of coats of nitrate to blend the seams. I didn't use any primer. If I do it again, I will use a coat of white primer. The white latex is a little translucent. The Behr is their sample jars, mixed to color. You can only get the samples in flat, no gloss. They were only $2.85 a jar, mixed. A total of about $12.00 for paint, and I've got enough of the trim colors for a couple more airplanes. I thinned the paint 50/50, then airbrushed it on. I had no problem with lifting with the masking, except on the fiberglass cowl, and that is because I did use primer on that and didn't let it dry good. The neat thing about the latex is you put on a coat, then hit it with a heat gun, then immediately put on another coat. It doesn't matter what the temp. or humidity is either. I called Jerry with Nelson Hobby paint, and he said I need to wait until I can't smell the latex before applying a clear coat. He thinks that will take about 30 days. I plan to clear coat it with the water based Nelson paint, but could use a spray lacquer as well. It is not a heavy finish at all up to this point. We'll see what I have after I clear coat it. Now that I know how easy the latex is to use I might try a gloss next time and avoid having to do a clear coat.
Jim Jorgensen
Offline Andrew Borgogna
  • Andy
« Reply #3 on: February 12, 2011, 09:45:10 PM »
Jim
My only question is why you chose indoor versus out paint?  My understanding is the outdoor paint has UV protection that indoor paint does not.  I too have used Latex house paint on my models but they were R/C giant scale planes, but my results were excellent.  I used Vista outdoor latex.  I use Behr in my house and like the way they will mix and sell the sample quantities.  Thanks for the information I may give this some consideration on my next electric project.
Andy
Andrew B. Borgogna
Offline jjorgensen
« Reply #4 on: February 13, 2011, 08:07:33 AM »
Andrew, the only reason I chose the indoor was the fact it came in the small sample bottles and I could get several colors to experiment with at low cost. Now that I know how it works, I'll probably go to the outdoor high gloss for the next project.
Jim Jorgensen
