  • August 02, 2025, 05:54:06 AM
Author Topic: Half A electric c/g  (Read 1625 times)
Offline jim gilmore
Half A electric c/g
« on: May 13, 2015, 11:14:35 PM »
Is the balance point of most electric conversions closer to being very nose heavy?
And if so should electric converted models have the tail lengthened or the nose shortened ??
This is for 1/2 A models.
I'm just wondering before completing any ore models should anything be changed ?
Whats in my stable to build.
ringmaster 207
pathfinder 1/2 A
Midwest p63 .015 size
midwest bf109 .015 size
Offline John Cralley
Re: Half A electric c/g
« Reply #1 on: May 14, 2015, 05:58:53 AM »
Jim, If you arrange to have the battery mounting to allow the battery to be moved, you can use battery to adjust the CG. On the Baby Ringmaster I found the battery needed to be mostly under the wing and I suspect that will be the case with most 1/2 A electric models. The exact location of the battery will depend on its weight. Start out nose heavy and work back until you have the CG were you want it.
Here is the arrangement for my E Baby Ringmaster.
John Cralley
AMA 52183
Central Illinois
Offline jim gilmore
« Reply #2 on: May 14, 2015, 12:01:47 PM »
I'm confused as to why removing a large amount of the wings strength of spar in the center section is the preferred method of installation?
When I get a chance I'll post a photo of the mounting method I'm working on.
I just wonder why the nose isnit just made either shorter or the tail longer to balance the weights
« Reply #3 on: May 14, 2015, 09:38:59 PM »
No spar was removed and the electronic components are on a plywood plate that spans from the trailing edge to the leading edge and is cemented to the bottom of the spar/rib/fuselage/leading edge/trailing edge. I seriously doubt that any wing root strength is lost. I wanted to retain the moments that were designed into the original Baby Ringmaster. You can do what ever you wish -- there is more than one way skin a cat.  ;D
John Cralley
AMA 52183
Central Illinois
Offline Keith Renecle
« Reply #4 on: May 17, 2015, 10:53:51 PM »
Hi Jim,
The CG is quite far forward already for most of the old 1/2A designs with Cox engines like the Babe Bee, Black Widow etc. Flapless planes need the CG quite far forward anyway. The Babe Bee and variant's were rather elegant in that the fuel tank was neatly stuck on the back of the engine. Just add 4 screws and a few drops of liquid and off you go! Now e-power comes along and has so many extra things to hide and mostly they look so messy with all of the wires and components. Johns method of putting the battery in the wing is really the only way to go and it does not make the wing weaker. I made an attempt to neaten everything up and it worked rather well for my 1/2A Sparky project http://stunthanger.com/smf/index.php/topic,37540.0.html
I used one of my Compact timers on one side behind the motor mounting, and the esc on the other. Some Velcro holds both in place. I have been thinking lately of doing a baby Yak with a radial cowl to cover these parts. Eric Rule has sent me a new flat small motor with the right Kv so I may just do that sometime soon. The e-power 1/2A's perform really well and you always get the motor to run well. I use the APC 6 x 5.5 E props to give decent ground clearance.
Keith R
Keith R
