  • August 02, 2025, 05:54:07 AM
Author Topic: More lipo questions  (Read 1195 times)
Offline Paul Allen
More lipo questions
« on: May 14, 2015, 11:27:24 PM »
Carrying on from the other post re lightest 3000mah 4s lipo,how can one work out if a
5s lipo of less capacity eg 2700mha will do the job,the Cobra motor I am using lists
Figures for a 5s setup and the weight for a Thunder Power 5s 2700 mah is the same
As a 4s 3000mah.
Offline Curare
Re: More lipo questions
« Reply #1 on: May 15, 2015, 12:57:24 AM »
Using a bit of maths, you can see that they're  similar.
Most batteries for other things use kilowat hours as their measurement. its basically energy over time.
if we mulitply our capacity and our voltage we'll get watt/hours, and divide by 1000 for KW/hours
so:
5s 2700mah :5 x 4.2v = 21v x 2.7 (Amp hours) = 56.7watt hours
4s 3300mah : 4 x 4.2v = 16.8v x 3.3(Amp hours) = 55.44 watt hours.
Rpm will be determined by KV, and power by the prop. You can get the same power with 4S but you'll chew more amps.
Greg Kowalski
AUS 36694
