  • June 17, 2025, 09:45:27 AM
Author Topic: electric fun in gym  (Read 2122 times)
Offline Igor Burger
Offline Jim Moffatt
Re: electric fun in gym
« Reply #1 on: March 22, 2010, 06:27:15 AM »
How much rudder and engine offset do the planes use?
Do any use flaps?
Offline Igor Burger
« Reply #2 on: March 22, 2010, 09:17:10 AM »
Beside one model, all of them are copies of that my old "GB r3 like" model, with minimal engine offset (sidewise), and straight rudder
that "other" model is form R/C kit and that one has all straight (sidewise ... I write sidewise, because motor has ~3degrees down offset)
however lines are approximately 20 degrees back, and that is also in-flight yaw, it does not need significant rudder and motor offset, because of well balanced side area, what is easy to do on such type of model (knife and glue are quick tools for that VD~ ) ... so that extreme yaw is then easy to trim by only minimal motor or rudder offset
means the line tension overhead does not come from centrifugal acceleration, but instead of that from lift on fuselage side, you can see that the area of fuselage is similar to that on wing :-)
flying is surprising, experienced c/l pilot will never believe, that it can do eight onerhead, because he will feel, that centrifugal force canno keep tight lines .. but it does, and more, it NEVER fall from lines, and it makes it good tool for learning figures
and no, we do not have flaps, flaps are not necessary, you can have any amount of area, since we do not have any wind and thus we can fly low wing load and if you look polar of flat wing, you will see that flaps are counterproductive and more, low lift coefficient means low turbulence on tips of wing and thus almost no self turbulence in calm condition of gym
Offline Jim Moffatt
« Reply #3 on: March 22, 2010, 12:24:18 PM »
Igor
Thanks very much!
Looks like I need to copy your designs. My latest flat foamy has a "fat' fuselage to help lift in the overheads, but I need to add more with the wheel struts like your plane has. Also I should switch from 6mm to 3mm foam.
I want to fly outdoors but in wind less than 3 mph.
I timed the laps on your videos and they were around 5 sec, the slowness amazed me.  I now see centrifugal force wouldnt keep them up on the overheads.  VERY INGENIOUS!!!!
Best
Jim
Offline Igor Burger
« Reply #4 on: March 23, 2010, 08:18:44 AM »
yes 3mm wil save you half of the weight :-)
gears, pans and legs are part of the flying area :-)
Online Matt Colan
« Reply #5 on: March 30, 2010, 04:13:36 PM »
Igor, I think that is the coolest thing!  What did you use to set it up?  I would really like to know  #^ H^^
Offline Igor Burger
« Reply #6 on: March 31, 2010, 03:33:08 AM »
it has 80cm span, 170g weight, 60W motor 32g heavy and 2s 800mah battery with Spin 11A ESC
Offline Vincent Corwell
« Reply #7 on: April 01, 2010, 01:37:53 AM »
Hi Igor
That looks like a typical F3P airplane, no servos or radio
no airbrakes, no ailerons, extra bracing , using the normal
rc motor ?
Could you show a photo of the bellcrank and leadouts please ?
I am very keen to try this !
Thank you for all your postings on Stunt Hanger
Vicente
Offline Igor Burger
« Reply #8 on: April 01, 2010, 02:26:25 AM »
Yes, it is almost usual F3P model, my first try was just that. But there are 3 differences, the nose has more side area, because usual F3P model has shorter nose, and that leads to more rudder offset for proper fuselage position with excessive outboard yaw (it is almost 20 degrees). And the secon difference is much stronger powertrain, it has 60W motor, larger prop and battery is 2s 800mah, while F3P uses 30W motor and ~300mah battery. And the last is, that we have aproximately 3 degrees down motor offset, while F3P little right, so the mainframe must be little modified, but that is easy to do by knife  VD~
CNCed bellcrank is on picture ... we all use the same
« Reply #9 on: April 01, 2010, 03:22:52 AM »
Your reply greatly appreciated Igor
Sorry...more questions please
I have the suitable batteries, speed controller, etc
on my F3P airplane, so I can build another copy
I will add 40mm longer to the nose ?
I presume a 10"x4" propellor ?
could you point me at a suitable Turnigy motor ?
I fly F3P in a local Gym and a CL plane would be terrific 1
thanks for you expertise and help
Vicente
Offline Igor Burger
« Reply #10 on: April 01, 2010, 03:40:49 AM »
Just make little bit wider or longer nose than on F3P, I can send you corel draw file with my model if you want measure what we have here, but I succesfully reworked model from this link, the difference was only little out rudder - it is not big problem, but fuselage makes side lift and outboard rudder makes it lower, but it will certainly fly.
http://rc-factory.cz/inshop/scripts/big_picture.asp?img=Clik 2.0.jpg
You will certainly need ESC with governor, I use Spin11. Motor is 32g heavy 1400rpm/V with internal resistance 150mohm (that resistance is important, becaus motor runs overloaded). I do not think you can find turnigy equivalent, we had bad luck with low cost motors, they easily burn, just imagine what happens with such small motor and such a prop. I would say it will need to be little bigger if you want use such types. This one comes from Czech and its name is Python 60. It is little more expensive than turnigy, but we all use it and it works well. Try to search some motor by KV and resistance and do not look to weingh, you will probably come to heavier motor, but I think such a model can carry it easily.
you can look also to this older page, pictures show shapes and areas. Span is 80cm.
http://www.rcmodely.sk/zobrazclanok.php?id=300
« Reply #11 on: April 01, 2010, 07:11:57 AM »
Me again Igor ! sorry to be a nuisance !
cant find Cemec web site on internet or a Python 60 motor anywhere
Some of the Axi motors are close but have 200-300 moh resistance
on most web sites the Watts per motor are not listed
( do you have a plan or sketch of the airplane please , that would Email ) )
Thank you again
Vicente
Offline Igor Burger
« Reply #12 on: April 01, 2010, 07:59:15 AM »
it is difficult with cemech, they found it is easier to resale stuff and that production is difficult :-), we ordered box of motors at once and that is what we fly now :-)
200-300mohm is too much, it needs 5-8A and it makes extra 2-3watts and it will also limit current and thus torque, it is really better to chosse larger motor ... problem ise really that cheap motors does not have Ri in parameters, probably because it is typically much worse than those more expensive, but may be scorpion can have good type
I can send you CDR file, can you read it?
« Reply #13 on: April 01, 2010, 08:06:18 AM »
I can buy Scorpion motors but so many types, need to know which one to get ?
I downloaded the cdr file from your link but my software cant read it
( I have Autodesk Volo View Express ) I can read dwg files and dxf files only
If I can pick a suitable motor I can modify the airplane until it is correct
thank you
Vicente
Offline Igor Burger
« Reply #14 on: April 01, 2010, 08:06:53 AM »
Friend of mine, Marep Petovsky did a pdf with dimmensions ... I will try to post it here.
It has czech comments, but I think all was already written here.
Offline Igor Burger
« Reply #15 on: April 01, 2010, 08:15:40 AM »
hmmm ... it is really difficult to find such a motor, may be this one: http://www.scorpionsystem.com/catalog/motors/s22/S-2208-30T/ but it ia over 10g heavier
Offline Igor Burger
« Reply #17 on: April 01, 2010, 08:30:20 AM »
Great Igor ! ! !
I printed the pdf and everything I need is there
Is "teziste" the balance point ?
I will buy the Axi motor and experiment
this will take 4-5 weeks as I will be on holidays until April 22
As soon as I have results I will be in touch
Many Many thanks for staying with me
Vicente
Offline Igor Burger
« Reply #18 on: April 01, 2010, 08:32:31 AM »
I see you are learning Czech :-))))) ... yes teziste is CG :-)))
« Reply #19 on: April 01, 2010, 08:41:25 AM »
Děkuji
Found words on google search !
Vicente
Offline Igor Burger
« Reply #20 on: April 01, 2010, 08:42:55 AM »
 ;D great
