  • July 31, 2025, 12:07:03 PM
Author Topic: "35" size motor selections  (Read 14378 times)
Offline John Cralley
Re: "35" size motor selections
« Reply #50 on: February 16, 2009, 02:38:54 PM »
Ok problem solved.
I just tached motor with a prop and it came in at 10,140 and the ESc is set for 10,000 so I'll take that. Alan was correct 14 magnets it is for the Turnigy 4042 motor.
I must say I am really impressed with the CC Phoenix ESC upgraded to the new firmware. I'm like a kid waiting for Christmas only I'm waiting for some good weather!!! LOL
John Cralley
AMA 52183
Central Illinois
« Reply #51 on: February 18, 2009, 02:18:06 PM »
Guys,
With the discussion on the AXI motor dropping magnets it seems that looking into "In-runners" might be an option. Soooo what NEU in runner fits for a replacement for the AXI2820/10 (IC 46) and then what one fits for the smaller "35" size application that we have be talking about here?
Best,           Dennis
Offline Mike Anderson
« Reply #52 on: February 18, 2009, 02:36:10 PM »
Guys,
Best,           Dennis
Maybe someone should be looking at these:
http://www.lightflightrc.com/HTML/products/ARC-36mm.htm
(Here is the text from that page)
ARC 36mm Motors:
• Dimensions: 36mm x 55mm
• Weight: 234g
• 25mm and 19mm apart mounting holes.
• 5mm shaft
• 4 poles
These motors are 55mm long. Known Rm (Kv) specs are below.
36-55-1 = (2800KV)              $69.95
36-55-1.5 = 0.014 (1850KV)    $69.95
36-55-2 = 0.022 (1400KV)    $69.95
36-55-2.5 = (1150KV)       $69.95
36-55-3 = 0.043 (950KV)      $69.95
36-55-3.5 = 0.064 (800KV)    $69.95
36-55-4 = (700KV)           $69.95
Mike@   AMA 10086
Central Iowa
Tags: motors
