  • July 14, 2025, 01:02:03 PM
Author Topic: Safety Bag  (Read 1812 times)
Safety Bag
« on: April 12, 2015, 11:43:21 AM »
It just occurred to me I keep 4 lippos in the same safety bag. If one should burn down it would certainly effect the others. What's the protocol, do you have a separate safety bag for each lippo battery?
Re: Safety Bag
« Reply #1 on: April 12, 2015, 12:10:23 PM »
I keep mine in an ammo box. These are steel sealed boxes that should contain any problems. If you use a good charger and inspect the packs for "Puffing" there should be no issues. Once a pack puffs I stop using it.
Best,     DennisT
Re: Safety Bag
« Reply #2 on: April 12, 2015, 05:28:56 PM »
Do you keep them all in the same ammo box. My point is you blow one you lose them all.
Offline eric rule
Re: Safety Bag
« Reply #3 on: April 12, 2015, 06:40:12 PM »
No protocol that I  am aware of. I think that common sense is what you should use here. If you are concerned with one blowing up and taking the rest with it then I think that you have answered your own question..
Re: Safety Bag
« Reply #4 on: April 12, 2015, 08:51:03 PM »
Just pulled the trigger on 3 more bags. Got them off eBay $3.50 each.
Re: Safety Bag
« Reply #5 on: April 13, 2015, 01:47:54 PM »
I picked up a steel lock box to keep them in. Separate lipo bags may not be a bad idea.
