  • June 21, 2025, 08:56:46 PM
Author Topic: Warm up of electric motors  (Read 2239 times)
Offline Kerry Ewart
« on: June 09, 2017, 09:04:05 PM »
A thought...
In cold temperatures (say under 10 degrees centigrade) should we be taking the time to warm electric motors like we would a IC with a short burst before we fly......what's everyone's thoughts..????
"If you cannot beat them!JOIN THEM.
Re: Warm up of electric motors
« Reply #1 on: June 09, 2017, 09:58:55 PM »
If it spins freely then you're good to go.  I can conceive of a motor tightening up from the cold, but I'd have to feel it turning to believe it.
Your batteries don't want to be too cold -- I'm not sure what the low point is, but I'd leave them in my nice warm car until it was time to fly.
« Reply #2 on: June 10, 2017, 06:59:45 AM »
Hi Kerry
The only moving part in the motor susceptible to the cold is the grease in the ball bearings.  At worse it will warm up nicely within a few seconds.  Bigger concern is the effect of cold on battery - it will act like the capacity has been lowered.  Keep them warm and block off any cooling air passages that route air to the battery.
« Reply #3 on: June 10, 2017, 08:06:47 AM »
Truly oddball cases aside, if you're concerned about operating temperature you can (and possibly should) partially block the cooling intake on really cold days.  I know people have mentioned it here, but I've never had occasion to.
This is probably true of the motors we use in our hobby, and the temperature ranges that we fly at.  Over aerospace or industrial temperature ranges (-40 to +85C) I've seen things bind up because of differential expansion or contraction of the parts.  That's usually been with parts that are way bigger than our motors, and had preloaded bearings, which is not something you want or need in our motors.  But it is a thing -- so if you happen to be flying in Alaska in the winter, or if you've been invited to stay in the Antarctic from May to September and brought a plane along, keep it in mind.
If you did fly in the cold, and you couldn't manage the plane temperature by keeping it in your car or wrapping a towel around the nose between flights, there are greases (generally both more toxic and more expensive) that work over wider temperature ranges.  A mechanical engineer I know at a prior sorta-aerospace job called our go-to grease "cocaine grease" because of the color and the cost per ounce.  I never asked how he knew...
Offline Fredvon4
  • Central Texas
« Reply #4 on: June 10, 2017, 11:53:02 AM »
As I sit in my shop on a 99F 86%H day outside...nice 75~77F 35%H in here---- I had to ponder the question
Then the epiphany!
Australia...now in their winter season
Tim, I did several VERY cold weather tests of a few Army Helicopters... before the days of our current cold test buildings at Aberdeen proving Grounds... Yes the Cold WX training and testing area(s) of Alaska
Your note made me grin as I remembered at -57F a Cobra Attack Helicopter (AH1P) Turbine engine start, as it spun up-- radially blew it self to junk.......seems a shaft speed of 100,000+ RPM needs a bit of lube that probably is a lot like your Cocaine Grease.. I learned that HS bearings do not like to skid, stall, and gall
ON topic
 I doubt that anything about electric flight in the mildly cold ( acceptable to a sane pilot) is of concern EXCEPT the battery temp... I guess an argument could be made that the prop is brittle and greater risk to damage... And I have no idea how brittle Mono kote or any other covering would be at really frigid temps, but suspect, as I thunk on it ---the whole air-frame is bound to be more delicate and brittle
What I do know for some cold WX playing with airplanes of the Glow fuel variety... cold, wind, and alcohol fuels hurt your hands...A LOT!
Fred von Gortler IV
« Reply #5 on: June 10, 2017, 12:05:03 PM »
If you were cursing any design engineers, that was my tribe.  My experience with failures at cold mostly involve looking into the window of an environmental test chamber and saying "it no workie" -- not actually having to, like, get cold.
And we only had to design for -40C operational, -55C storage.  Although we would quietly test all of our junk by doing an overnight cold soak at -55C, and then immediately warming it up to -40C and turning it on.
(I like -40, because you don't have to say whether it's -40C or -40F.  BTW.  Cuz I'm a nerd.)
