  • July 29, 2025, 09:25:38 PM
Author Topic: new zigras power settings vs rpm on the older pot?  (Read 1974 times)
Offline bob branch
« on: April 27, 2007, 09:00:29 PM »
Got my new electric smoothie into the air today. Used the same power system as before with the older zigras timer with the pot. I had set it up for 9800 rpm on the pot in governor mode. Now I have put in the new zigras timer that allows power output to be selected digitally by 2% increments. Can anyone give me a few % power settings and coresponding rpms they have found the Axi 2826/10 on a 4 cell lipo to put out so I have a reference to start from. Hate to waste an entire battery or two narrowing it down if someone can give me some data.
Bob Branch
Offline Dean Pappas
Re: new zigras power settings vs rpm on the older pot?
« Reply #1 on: April 28, 2007, 10:25:35 AM »
Hi Bob,
If you have a pulse width meter, then 10,000 RPM is right about 1380 microseconds.
If you don't, then ... Sorry, I've got nuttin' fer ye!
Vexa RC make a nice one, and Radio South (say hello to Tony for me) makes a less expensive and perfectly good one.
Hunt inherited mine!
Let us know what you end up with!
Dean
Dean Pappas
« Reply #2 on: April 28, 2007, 11:20:40 PM »
I am not sure here, but couldnt you use a tach, set it, run it, read the tach,shut it down and adjust it  by how many percent different you want the rpm?
Offline bob branch
« Reply #3 on: April 29, 2007, 06:40:22 AM »
Mark
That is the approach I am taking. 80% appears to produce 10200 rpm.
bob
