  • August 01, 2025, 07:54:36 AM
Author Topic: Electric Motor Tests  (Read 6939 times)
Alan Hahn
« on: May 04, 2008, 12:59:03 PM »
I think I have mentioned a couple of times (at least!) that I have been winding some motors. Yesterday and today I got a chance to do a some testing. I learned a little, and got confused a lot. HB~>
In these examples, I was looking at the motors I've been using for my E-Nobler, specifically the Scorpion line. They are characterized by a numbering scheme similar to the AXI. In my case, the motors are the 3020 and 3014. The "30" is the diameter of the armature, and the "20" (or "14") is the magnet length. Finally the number of turns are appended at the end. What I tested was the stock wound 3020-12, my own wound 3020-16 and 3014-16. Except for the magnet and armature length, the 3020 and 3014 are mechanically identical.
What I have been trying to figure out is how to select a motor from among the myriad options one is confronted with. Most manufacturer's have "lines", based primarily on diameter (stator or sometimes the outer can), then lengths (8 mm to 32 mm in the case of Scorpion) and finally the number of wire winds. In any diameter and length category,the "kV" of the motor is set from the number of winds, the lower "kV" having more turns of finer wire (or the equivalent). As a note, within a diameter class, a longer motor will have a lower "kV" than a shorter motor with the same number of winds. So my 3020-16 has a "raw" kV of 880 while my 3014-16 has a raw kV of 1265. By raw kV I mean it is just the max rpm I measure with no prop divided by the applied voltage as measured by my Astro Whattmeter.
So how do you choose? First it depends on what your battery is going to be. I make that decision based on space and weight availability. In an ARF you more or less have to go with what you have, unless you want to do some major surgery. Also batteries are really the major expense, each one costing abut what the motor costs (or more). I will also mention that these decisions are not linear, since at this stage of the game, we are all going a little on other's experiences and more than a little guessing. It is certainly better to error on the over-capacity than under, since "over" means that you may be carrying around a little weight penalty, but "under" means you can't make the full pattern--either by length or by power. I admit I cut a little close to the limit, and have been burned at least once (so far). I also decided to try and fix on the 2100mAHr cell since it really seems to be one of the most popular and least expensive sizes. So once I choose the cell size, the next issue is the number of cells and how you arrange them. What ultimately matters is the total energy that the battery pack contains--it doesn't matter if you arrange things in series or parallel, until you chose the motor that is.
So on one of the other threads, a reasonable rule of thumb is to have a kV so that the target rpm is ~70% of the no load rpm for a given battery pack. The other thing to remember is that the pack voltage drops over the run, so don't choose the max voltage of the pack at the start, but rather the "safe" voltage near the end of a run. Another rule of thumb is that you  should never use more than 80% of a pack's capacity (this is for Lipo packs) in a run. For a lipo, this "safe" voltage is 3.7V per cell. For a 4s pack, that means the "safe" voltage is 14.8V, and for a 3s pack 11.1V.
For the props I use, the target rpm's are "typically" in the 8000-9000 rpm range  for props with diameters from 10" to 12" and pitches from 5" to 7" (although I might start trying higher pitches). So with a 4s pack, that implies a kV greater than 770 rpm/Volt (for rpm target at 8000). The 70% number gives some overhead so that when more power is needed in the overheads, you can still get it from the system.
For a 3s battery, the target kV would be ~1030 rpm/Volt.
For the ENobler I started out with the 3020-12 stock motor (kV=1088 rpm/V) and a 3s battery---two 3s2100mAhr packs hooked up in parallel (~3s2p4200 mAHr). This was originally a guess--I was sure it would be enough to power the plane. And it was, but I discovered that I was only using about half the total capacity, but carrying around the full weight of 6 cells. So I thought that I could replace the setup with a single pack made up of 4 2100mAHr cells (a 4s1p 2100mAHr for 2/3 the total weight -6.7oz). I should mention that the 2100mAhr cells have a continuous "C" rating of 18 (~38A). Therefore the 4s pack has a 38A max continuos draw while the two 3s1p 2100 packs in parallel can supply twice that. In flight I am drawing about 18A in level flight, and up to 30A in the overheads from the 4s pack.
However I was now wondering if the original 1088 rpm/V was using my precious "Joules" efficiently, since it wasn't well matched to the 4s battery. I know from previous experience that my CC 35A ESC seemed to be pretty good in efficiently running at partial throttle, but there may be some room for improvement by going to a lower kV motor---but how much?
Actually I already had a Scorpion Motor kit that I bought for the ENobler, even before I bought the 3020-12 motor (I was in a hurry to get the ENobler flying before winter set in last year). So I thought I would wind it for a lower kV. I thought a 16 wind motor would get me a kV in the 800 rpm/Volt range, and I also saw that I could get more copper in the wind than the stock 16 wind motor (using a lower gauge wire--19 AWG). So that is what I did. It turned out that the raw kV ended up as noted above 880 rpm/V (showing it all isn't quite a science).
So as mentioned before, I finally tested things out yesterday and today, and I will post the results such as they are in the next post--but need a rest right now!!
Alan Hahn
Re: Electric Motor Tests
« Reply #1 on: May 04, 2008, 01:01:14 PM »
Here is a picture of the test stand in the garage.
Alan Hahn
« Reply #2 on: May 04, 2008, 01:30:41 PM »
The test was done on 3 motors, the stock 3020-12, and my own wound 3020-16 and 3014-16. The latter motor was wound to try on my Brodak Super Clown, but I was also curious how it would fare. It is lighter than the 3020 motors.
I first measured the 3 motors, using an APC Thin Electric 11-5.5 prop. I chose this prop because it gives a static draw similar in power as what I see my ENobler is drawing in level flight. The motors were tested with both a 3s1p 4000mAHr battery (the one that Brodak sells for the Super CLown) and one of my FMA 4s1p 2100mAHr batteries I use for the ENobler. This test was done yesterday in my garage with the setup you see in the photo. I used the JMP-2 timer and CC35 ESC (running in governor mode) from the actual E-Nobler setup. Currently this is set for 8100 rpm. I verified the rpm with my TNC tach. I measured the power (V, A, and Watts) with an Astroflight Whattmeter.
Saturdays results were as follows
motor           3s Watts measured          4s Watts measured
3020-16              230 Watts                      250 Watts
3020-12              240 Watts                      250 Watts
3014-16              250 Watts                      260  Watts
I was a little disappointed by these results which were at best a 5% effect for my own hard work. However you can see the 3s is generally more efficient, and this I assume is due the the ESC being more efficient at a higher throttle setting. But is really isn't a big deal.
I was also a little puzzled, since my 3020-16 seemed to be a little better at 3s, but the same at 4s. So the more I thought about it the more I though that maybe I wrote down the numbers wrong. Also I thought I should see what happens at a higher load setting, so I decided to make a measurement with the 12-6 APC Thin Electric prop I am now using on the ENobler.
So I went out today to the garage and set things up again. This time I let the motor run a little longer to make a few more data recordings to see if things were really stable. On the first measurement I noticed that the watt measurements were moving + 10 Watts or so, and I realized that occasionally a light breeze would come in the garage and this caused the difference. I was even more surprised when I was walking behind the prop (between the test stand and the back wall of the garage) and discovered the reading were changing---and that the prop wash was actually causing quite a back breeze from the wall!. Anyway I turned the test stand around so I was blowing it out the garage door, and also tried to make measurements when the outside breezes had died away. Now I understand why I have been noticing the upwind/downwind oscillations in amperage and power when I look at my onboard data recorder while flying!
So here is today's data. I did not measure the 3014 today or use the 3s battery. I recorded several measurments, to give some idea of the scatter.
motor         APC TE 11-5.5 prop          APC TE 12-6 prop
3020-16            246W, 240 W               397W, 385W, 400W
3020-12         263W, 268W, 263W          440W, 438W, 420W
So the 3020-16 is better, and I will mount it, sinceI am cutting it close on my 4s batteries in a typical flight, so it will help a little. What I am not sure of is where the advantage is coming from---a better match of kV to the 4s battery, or the better packing (more) copper around the armature teeth.
So my bottom line is that if I had a motor already, it is not worth buying a newer one to match to the battery if all you are trying to do is to make things more efficient. Also it is tough to setup a good test stand to measure things like this because it is very sensitive to environmental conditions.
« Reply #3 on: May 04, 2008, 09:13:47 PM »
Another nice piece of work Alan!
I will be re-reading it and trying to digest it again - I'm sure several times.  One question that does come to mind:  You mention your target kV but then mention that you expect to experiment with higher prop pitch = presumably for more speed at a given setting.  Wouldn't it work to use a slight higer kV motor - say a 1200 instead of a 1000?  It would seem you could keep our prop and throttle setting and gain airspeed.  Power would increase, but it will with higher pitch too...?
Alan Hahn
« Reply #4 on: May 05, 2008, 08:52:18 AM »
Dennis,
It has been claimed that a "square'r" prop (pitch closer to diameter) is more efficient. That's all I meant. So of course I would run at a lower rpm for that test.
There is nothing god-given about pitches in the 6" range---except that's where glow engines rpm sweet spot use to be --(insert your favorite Stunt-God's name here  VD~!) Now it seems closer to the 4" range since the newer (in last 25 years or so!) engines prefer higher rpm to make their power.
Of course electric motors have freed us from this tyranny, by choosing kV, you can make your torque and power almost anywhere. Yet we still seem to stick with it--out of force of habit?? Z@@ZZZ. I am not sure how it will turn out for the stunt application.
At some  point I think Dean will "pipe" in and tell us that's where the RC Pattern guys have gone! Iam guessing (or slowly recalling) that is because the 4 stroke engine tends to make its torque at lower rpms, in a way similar to the electric motor.
Offline Dean Pappas
« Reply #5 on: May 05, 2008, 11:42:55 AM »
Should I? S?P
    Dean
Dean Pappas
« Reply #6 on: May 05, 2008, 11:54:27 AM »
Alan,
Very interesting information on the motor test. Did you measure the resistance of each motor? It would be interesting to see how the stock motor compares to the rewound ones. My guess is that the one with the lower resistance will likely be more efficient and would run cooler.
On the props one thing that was learned with pipe setups was that lower pitch at higher rpm allows the plane to re-accelerate out of the corner smoother. With the electrics we seem to be able to hold rpm even better than the pipe engines and can take a little higher pitch and still accelerate smoothly. My feeling is that up to about 6 ish should work OK. In strong wind we may want to use a little less pitch just to make sure we get the prop pulling a little stronger. I have had very good performance with the APC E 12x6 cut and repitched to 11 3/4 x 4 3/4. This prop pulls very strong in the wind. My supprise was when trying the APC E 11 x 5.5, it had no bite at all and lost almost a full second lap time even those the pitch is higher. It might be that the APC E 12x6 has more undercamber then the 11 x 5.5 and therefore more effective pitch but it is really noticeable on a larger, draggy ship. Did you fly the 11x5.5 ?
Best,        Dennis
« Reply #7 on: May 05, 2008, 01:21:32 PM »
Should I? S?P
    Dean
JUMP IN Reverend Deano!
Alan Hahn
« Reply #8 on: May 05, 2008, 01:33:41 PM »
Alan Hahn
« Reply #9 on: May 05, 2008, 01:44:01 PM »
Alan,
Best,        Dennis
Some quick answers:
Since I have more copper in my hand wound motor (the one with 16 turns), it should be more efficient than the stock 12 turn motor. However it probably has more resistance simply because of the 16 vs 12 turns.
Secondly about piped engines and their choice of props: Sometimes it is difficult to disentangle the causes from the effects. Piped engines may prefer lower pitches because of their available torque. They may not be able to really handle higher pitch props. I would be assuming equal diameters (not wide diameter low pitch vs smaller diameter high pitch). With electric you are a lot more flexible where you want to make your power and torque. But we will see---as soon as I recover from a small mishap on takeoff this lunch :P. Fred captured it on film so it probably will appear soon! Electric does have some interesting features compared to glow when things go south.
On the 11-5.5, yes I have flown it and of course I ran it at a higher rpm (8900 -9000 rpm). I wanted a bit more vertical pull so that is why I just recently put on the 12-6. However if you look at the two, the 12-6 is reasonably wider prop, so even cutting it down to 11, I bet it will have more blade area then the 11-5.5. So I am guessing it will give more thrust than the 11-5.5 just because of that.
« Reply #10 on: May 05, 2008, 02:25:29 PM »
Alan,
Agree on the electrics giving us the ability to pick a wider range for where the power is applied. I think that we have a wider range of usable pitches also. The higher pitch will likely work on the low drag designs but if you have a ship with a very thick wing we may still fine the lower (< 6") to have some advantage to accelerate out of the corner better.
On the APC E 12x6 I agree there is something about that prop that gives lots of thrust. I did some prop test over the weekend and found that the Rev-up 11 1/2 x 5 was about the same as the APC_E 11x5.5 lost almost a sec of lap time for the 8800 rpm set point. The tried a Top Flite Power Tip 12x6 it was as good as the APC_E 12 x6 at 4.92 sec lap time @ 8800 rpm (I think it was right at the edge of the governor). The last one I tested was a Zinger 12x5 that was cleaned up a little (rounded the LE instead of the stock square edge). This prop was also pretty good at 5.3 sec lap time @ 8800 rpm. It seems the thick airfoil props pull better then the thin one (ie rev-up & APC_E 11x5.5) and the ones with lots of undercamber and thin airfoils also pull with lots of thrust. My guess is the undercamber on the 12x6 APC_E and the philips entry on the TopFlite give more "effective" pitch then the measured 6" and that's were the additional thrust is coming from. But they work!!!!
Best,         Dennis
Offline Dean Pappas
« Reply #11 on: May 05, 2008, 03:20:30 PM »
Hi All,
I posted something a few hours ago, and now I don't see it. Drat! wasted typing ...
In the dark Arts group, we have seen that as long as you wre within the engine's happy RPM range, that lower RPM and the added pitch to go along with it would improve efficiency, and often allow the addition of a teeny bit more diameter. There's whare the payoff was. All of this was being done within the framework of the Pattern noise rules.
Along came electric, and noise was almost a non-issue. Instead, we had the great geared versus outrunner debates. End result? Geared motors turned higher pitches more slowly and outrunners had higher Kvs and RPM. Early on we only used freewheeling for downhill braking and the following became evident. When the gear jobs were run with high pitches, the brakes were still pretty good. When outrunners werre run with high pitches, the braking diminished dramatically. Oh yes, and diameter always made things better.
Nowadays, all electric pattern setups have killer brakes because of the regenerative aerobatic brakes that many ESCs have in airplane mode. This feature is not available from anybody in heli governor mode and it isn't likely, either!
For now, running as low a pitch as you can stand will lead to better brakes. How low? In order to avoid prop tip buzzing, use the rule of 130. 13" diameters can turn as fast as 10,000 RPM and not get noisy, and 10" diameters can turn 13K.
What you're stuck with is between 4-1/2" to 5-1/2" pitches at 62 feet, and 6" to 7" at 70 feet.
The problem with low pitches is that electric motors absorb more power when loaded down. It is erroneous wet-hangover thinking to get more acceleration with low pitch, unless you can carry more diameter as a consequence.
later,
Dean
Dean Pappas
Kim Doherty
« Reply #12 on: May 06, 2008, 03:38:30 PM »
later,
Dean
Hi Dean,
Just to clarify and amplify a couple of points.
The Schulze 18.46K F2B ESC runs in heli governor mode WITH BRAKE ENABLED. This is how we stop the prop at the end of the flight. As we move forward we will be working to develop intelligent on board control of the brake from our processor. (being aerobatics we want to control the horizontal and the vertical)
Low pitch high rpm is simply a remnant of the need to prop the plane to operate in the power band of the engine. If the engine will not bog down and will not accelerate away, there is no need to worry about the wind or accelerating out of corners.
The biggest bang for the buck with any propeller is more diameter. Since we are limited in diameter by gear height and prop clearance we then must get the next biggest bang for the buck and that is more pitch since it is much more efficient. (high rpm low pitch setups simply whip the air white causing drag)
I think you can easily run eight inches of pitch if you have the power to turn it. I have and I still have all of my fingers and toes. Brain is a bit cloudy but ..........
Kim.
« Reply #13 on: May 06, 2008, 10:10:57 PM »
Thanks for the insights.
and Alan, again, NICE JOB on the tests!  H^^
« Reply #14 on: May 07, 2008, 08:47:20 AM »
ESC governor with brake - this past weekend I did some prop testing, it was pretty strong winds > 15mph and on one flight the motor cut just before down wind. The motor was still at a fair rpm and acted as a big brake at the front of the ship, as the ship slowed and came to down wind the wind hit the back end and flipped it up and in. This caused a momentary lose line condition and the ship then lost almost all airspeed and just about fell out the air, I just caught it and it pancaked in.
Point being that if the motor cuts in the wrong spot in high winds with the prop free wheeling it could cause lose of control and a crash or at least a poor landing. If the Schulze 18.46K F2B ESC has the governor w/brake feature it is a strong advantage in windy conditions for landing points.
Dean - is there no chance that CC will provide special CL software add-in feature to allow the governor-brake mode? I can see that they would not want this to be a standard feature but as a special add-in for us CL people to purchase it would keep the Heli guy from activating it by accident and still allow us to get what we need.
If no - once we know the % throttle setting using the governor for the needed rpm, could we set up the motor start and end settings in the timer to simulate the flight power settings that the governor would have provided. ?Then not set the ESC to governor mode, but set it to use the braking mode? Can we get close to the same performance?
Best,           Dennis
Best,          Dennis
Offline Dean Pappas
« Reply #15 on: May 07, 2008, 12:18:53 PM »
Hi Dennis,
It's quite an airbrake, isn't it!
The technique that Bob has developed is that as soon as he gets the throttle-blip "5 seconds to quitting" warning, he goes to maybe 30 degrees altitude, and as soon as the motor actually quits he smoothly dives to 6 feet and whips as he pulls out. He maintains enough airspeed for good control, and the airplane settles promptly when he stops whipping. If you are not whipping then you are landing in 1/4 lap!
Even if you have a brake, the first one, two or three seconds after the drive transistors are turned off will have to be  allowed for the RPM to decay a bit before the brake gets turned on. There is also a ramp-up of the braking effort: it doesn't all come on at once. Otherwise you will twist the nose right off the ship. So even when we do get a brake, you must still be aware that there is a fair energy loss that must be dived or whipped through.
Yes, there is a good chance that CC will do the Stunt-Mode. We just have to convince them that hundreds of y'all will buy them! If I was to order a hundred ESCs with the special programming and resell them to you all, it would get done soon. Anybody have that much money available to start a business?
As for the last question: can you raplace the governor with a steadily increasing throttle setting ... No. The governor works during the maneuvers to stabilize the airspeed. That's the wonderful thing about the CC governor. With the gains and response time cranked, it responds about as fast as we execute square corners.
Hope that answers,
Dean
Dean Pappas
Kim Doherty
« Reply #16 on: May 07, 2008, 12:42:15 PM »
Dennis, Dean
You should know that we first tried to work with CC when we were developing our package. They had less than zero interest. Even if you do get them to enable the "Brake" function in governor mode, there are so many other parameters that will not be totally optimised for C/L PA. (even with all of the settings CC allows you to adjust)
I am not sure what the hesitation is in using the Schulze ESC other than cost. (you get what you pay for) My guess is that we can get more done by supporting the company that made the first dedicated C/L ESC than by trying to get five other companies who are not interested, to make one. (isn't going to happen  :-(   )  Please note that I do not receive ANY compensation from Schulze.
Kim.
Alan Hahn
« Reply #17 on: May 07, 2008, 01:00:00 PM »
As an aside, and not a solution, I've thought about using the timer to ramp down the throttle over a couple of laps, so that you would actually be landing at a low, but not zero throttle. I have the CC ESC's so that's where I am coming from.
On both the Jmp-2 and Ztron, they have two flight timers running. One is the total time, the other is called the "First Flight Time", or something like that. This feature was enabled (I think) to allow the throttle (set for "First Flight Time" to ramp up from the end of the "First Flight Time" to the whatever throttle setting you set for the Total Flight time. I actually use that feature on my 1/2A setup where the plane is flying ballistically anyway and it helps compensate the normal voltage droop you get from a lipo in the latter 2/3 of the flight.
With governor mode, it is more of a PITA because I then need to input two throttle settings to keep rpm constant through the flight. However I could set First Flight time ~10s less than Final Flight time, and then the final flight throttle at 0. The only issue is how the ramp up/down speed plays with that. So I would be landing at 1/4 throttle and then taxi to a stop. Right now the plane basically plops down with a thud (not too elegant!).
Maybe this suggestion can be classified as making lemonade from a lemon!
About the Schulze, I really don't know much about it--who is the dealer. Also I tend to be more of a hacker (as I am sure everyone agrees!), so I am not totally dedicated to achieving Stunt Nirvana. ;)
Offline Dean Pappas
« Reply #18 on: May 07, 2008, 01:07:38 PM »
Hi Kim,
The prospect of using a low percentage duty cycle brake to make the RPM control loop gain more nearly the same in both directions is fantastic. #^
Aside from expense, I have been trying to cultivate a domestic source for a Stunt optimized product. I may give up, but not quite yet. With that added feature, it sure will be hard to argue against using the Schulze. I don't get any compensation from Castle either, but I sure have been plugging their product.
As an aside, the system Kim is describing would be capable of dropping excess RPM as fast as it can add RPM when too low. Right now all we have is drive and coast rather than drive and brakes, kind of like the cruise control in your car. This will be very good in strong runway wind.
later,
Dean
Dean Pappas
Offline Archie Adamisin
« Reply #19 on: May 07, 2008, 01:32:37 PM »
Dean/Kim,
Does the Hacker RPM control work this same way as the Shultze?  I am not opposed to the Shultze controller either, but I have known Patrick for a long time and like his controllers.  I haven't ever used a Shultze, but I know others who have with great success in other facets of the hobby.
Archie Adamisin
Muncie, Indiana
Archie Adamisin
Burlington, KY
Offline Dean Pappas
« Reply #20 on: May 07, 2008, 01:41:26 PM »
The North-American dealer for Schulze is in Canada: www.icare-rc.com.
He also imports the Plettenberg line of motors. The Plettys are good stuff, if also not cheap.
The fellow in charge is named Etienne ... and I'm sure I've misspelt it, but he's a good guy.
Dean
Dean Pappas
Offline Mike Palko
« Reply #21 on: May 07, 2008, 05:04:39 PM »
Hi Guys,
   As of last week Joe Ford of CC said the new "stunt" software is almost ready to go. Now just how long is "almost". ???
   If the Schulze ESC works with my new setup I will be using one this year. It is designed for higher pole counts, which is limiting my low RPM range. Right now with an 8 pole NEU motor I am getting a low end speed of ~8,750rpm. It should be usable, but I won't know for sure until I get some flights in. I believe in what Kim says (I have seen it first hand) and hope to see even better performance from the Schulze. If not I have a CC-45Hv as back up.
Offline Dean Pappas
« Reply #22 on: May 07, 2008, 06:52:08 PM »
Hi Mike,
Is that in governor high or governor low mode? On 70' lines with a 12 X 6 or 12-1/2 X 6 you shouldn't ever need to go below  9,000.
I seem to remember not being able to get above 9,000 RPM with a 14-pole motor in the low range, so the 8 ought to work with a reasonable pulse width.
later,
Dean
Dean Pappas
Offline Mike Palko
« Reply #23 on: May 07, 2008, 09:11:26 PM »
Hi Dean,
   The RPM was actually a low of 8,850 not 8,750 (my mistake) and that was with the NEU/Schulze combination. The pulse width was 1.1mS in low governor mode.
   I spoke to Kim about the Schulze ESC and he tells me it is designed to work between 1.1mS and 2mS with 10 and 14 pole Plettenberg motors. The resulting RPM range in low governor is 7,000rpm - 12,000rpm.
Offline Dean Pappas
« Reply #24 on: May 08, 2008, 12:42:51 PM »
Hi Mike,
That is going to be tight, but it will work..
Using my rule of thumb of setting the RPM to 75% of Vbatt * Kv with the 675 Kv Neu 1907, you get 9300.
At 9300 RPM, with 70' of line and a 5.25 second lap you get a 6-1/2 inch pitch. APC make a 12-6E and a 13-7E.
You don't really have the ability to set for the 7" pitch, and 6" should be okay. I'd probably start with a 12-6 and try pitching a 13-7 down to 6-1/2 and clipping if necessary for current draw. You have a narrow sweet-spot to work in, but there is one!
I'll bet you didn't need me to tell you that,
Dean
Dean Pappas
« Reply #25 on: May 08, 2008, 02:46:24 PM »
Will the Schulze ESC work for the AXI 2820/8 size motors set up for 10V pack?
Best,          Dennis
Offline Dean Pappas
« Reply #26 on: May 08, 2008, 03:17:44 PM »
Hi Dennis,
You should have no problem whatsoever.
Dean
Dean Pappas
« Reply #27 on: May 09, 2008, 07:55:45 AM »
The model of the ESC that Kim indicated was the Schulze 18.46K F2B. Is this sized for 18V only or can it take lower voltage? Looking at the website it is the only Schulze model that seems to have the "CL governor/brake" is there others?
Best,      Dennis
Offline Dean Pappas
« Reply #28 on: May 09, 2008, 08:25:38 AM »
Hi Dennis,
It looks like the Schulze works on 4 or 5 cells, based on the data I found at the Icare-rc.com site.
I don't think it has a BEC, so you'll need a commercial BEC regulator. Lots of outfits sell them.
I'll go look at the Schulze site from Germany to see if it works on 3 cells.
Right now it is the only one.
Dean
Dean Pappas
Offline Dean Pappas
« Reply #29 on: May 09, 2008, 08:33:02 AM »
Hello again, All ...
The Schulze site http://www.schulze-elektronik-gmbh.de says that the 18.46 series controllers work from 2 to 5 LiPO cells but have no BEC.
Can you canfirm this Kim?
Dean
Dean Pappas
Offline Mike Palko
« Reply #30 on: May 09, 2008, 05:02:12 PM »
Hi Guys,
   You will need an external BEC to run the Schulze 18.46K F2B timer and it will work with 2-5S lipo's.
Offline Thierry SAUNIER
« Reply #31 on: May 15, 2008, 03:12:27 PM »
Hi, all...
I can confirm the Schulze 18/46K-F2B works ok with 4 or 5 cells. You need an U-Bec voltage regulator (approx 10 more grams) that you can install "in line" with heat-shrinked material wrapped around.
It seems that this ESC needs lots of cooling air on it's fins..., my last two flights were stopped after 3 mn , the ESC falling into security (thermal I guess). The max in flight amps were only 35A, with a max wattage of 600W
Concerning the props: I use the APC-E 13 X 6.5 at 8250 rpm .This is a standard APC size. No need to modify a 13x6 or 13x7. The JMP is set at 1,8 ms
Regards, Thierry
Offline Mike Palko
« Reply #32 on: May 15, 2008, 10:00:10 PM »
Thierry,
   What motor/battery combination are you using with the Schulze? During the flights that shut off due to thermal overload did you have air flowing over the ESC and can you confirm it was thermal related or was that just a guess?
   I haven't experienced this problem with my Schulze yet, but I will be sure to measure temps after the flights.
« Reply #33 on: May 16, 2008, 03:51:12 PM »
Mike,
Not sure it' s thermal related, but I only guess it is.
The Schulze was "finger hot", i forgot to measure the IR temp on it after landing (with gear up....)
I'm sure I do not have enought airflow on the ESC, I will have to modify and make more trials.
I join he Data Log of this short flight
Anybody has an idea on the problem?
Keep your lines tight, Thierry
« Reply #34 on: May 16, 2008, 03:57:59 PM »
Next,
On the D 520 the motor is a SMT 3600, it is a "french wired" AXI 28/26/10-12 with a Kv of 730 + Evolite 5S 4350 mah+ Schulze F2B+ U Bec+ APC-e 13 x 6.5
On the above graph, what you see after the 3 mn flight session are short ground motor trials in order to try understanding the reason of the cutt-off.
Rgds, Thierry
Alan Hahn
« Reply #35 on: May 16, 2008, 04:00:25 PM »
I am a little surprised by this, since we aren't really pushing these things. I have touched mine from time to time, and really haven't felt it was out of the ordinary. Now I have a CC Phoenix 35 A ESC. I do have it oriented just behind the opening in the cowl ("standard Nobler-like slit cutout in the cowl). I am guessing it is getting plenty of air.
My ESC is claimed to have a resistance of 0.0045 ohms. My average current is running at ~20A. Actually the instantaneous current is higher since I think I am running at about ~60% WOT (a guess), but ignoring that, I calculate that I am dissipating on the order of 2 watts. Actually it must be higher than that due to the power going as the square of the current, so the duty cycle isn't just an average.
Offline jim gilmore
« Reply #36 on: September 07, 2009, 01:16:11 AM »
while your motor test stand looks very simple, what is attaching the 2 pieces of wood together is it just (2) pieces of 1x2 pine ?
For reassurance I'd add a 1/16  or 1/8 gusset on each side of the joint to make sure the lo9ad never causes that joint to give out.
Alan Hahn
« Reply #37 on: September 07, 2009, 07:46:25 AM »
Jim,
It was made out of some scraps of cut 1 1/2" x  1" pine (actually 3/4" thick). I cut a ~3/8" deep dado in the bottom piece (~3/8" from the end). The vertical piece is glued into the slot, with a single finish nail (probably a 1-1 1/2 inch long, not sure) also providing some strength. The width was just enough for the motor mount of a Scorpion motor.
The reason you can get away with something like this is that there is so little vibration--just the thrust of the prop, which is "only" a few pounds or so for the motors and props I use.
Offline Keith Renecle
« Reply #38 on: September 09, 2009, 11:40:04 PM »
Hi All,
Thanks again to Alan for starting this "juicy" thread. Igor has told me that the newer range of Jeti Spin esc's have the option of governor mode with brake. The Jeti range is a little cheaper than the Schultze, and with the optional Jeti Box, they are easy to program. If you fly FAI rules, then the brake is necessary for your landing points. As some have found out as well, it's also nice to have the propeller braked in lots of wind. The FAI ruling was in fact to prevent a programmed landing with a progressively slower rpm. This would be an unfair advantage over the i/c engines.
The only thing that I have against the Jeti esc's, is that they have lousy, or no short circuit protection. I have managed to burn out 3 of them already. Two of these were at the last world champs when my motor wires burnt, and the last one at home when I managed to jam the prop on start-up by accident. O.K.....I am naturally clumsy, but I think that if my el-cheapo Hobbywing esc can shut down, then Jeti can also get it right. Other than that, the Jeti Spins work very well and program easily with the Jeti Box. My last unit did have the brake option, and Igor talked the Jeti guys into making him just 10 units with the added brake feature. That is not too shabby in my book!
Keith R
Keith R
Offline Igor Burger
« Reply #39 on: September 10, 2009, 01:00:17 AM »
Hi Keith,
The newest standard Jeti Spins hava brake in Heli 3D mode. So you can get it is shop. Unfortunately they are not water proof, so we still use special c/l version coated against water.
They say it will last more water than pilost ... but I thing do not know C/L guys and it is still better to keep it dry somewhere deep in fuselage :-)
