  • July 29, 2025, 08:34:41 AM
Author Topic: Electric ARF Flite Streak..?  (Read 3862 times)
« on: January 28, 2008, 08:20:18 PM »
Just wondering if anyone has done it?    I'm just curious to what electric motor & combination to use as to get comparable performance of the O S .20 FP with the 2030 muffler.
Something like this...  http://www.flyinglines.org/Electromaster.html
Thanks in advance.
Alan Hahn
Re: Electric ARF Flite Streak..?
« Reply #1 on: January 28, 2008, 10:06:48 PM »
I'd recommend a Scorpion 3014-16 (kV=1187) with an APC 10-7 Thin Electric prop turning in the 8-9000 rpm range. This could probably run just fine with a Castle Creations 25A Phoenix ESC in governor mode, and a FMA 2100 mAHr 3s Lipo Battery. I use the JMP-2 timer, but the Zigras works as well. Currently I am using the stock Brodak motor, but plan to switch to the Scorpion as soon as the weather permits!
This is basically what I use in my Brodak Super Clown E-Arf. I think you can see some of my results by searching in this forum. My SC fully loaded is 28oz.
I fly a TF Flite Streak Arf with a Fox 15 BB. It is a very light airframe. Main trick is to figure where to stow the battery on that short front end.
« Reply #2 on: January 29, 2008, 10:48:32 AM »
Thanks Alan, that is some good info there.  H^^
« Reply #3 on: February 11, 2008, 10:52:08 AM »
Joe,
You might be able to modify the upper outboard wind to include a hatch for the battery. You will need to reinforce the leading edge with a vertical shear spar ( say 1/8" hard balse running the lenght of the planking). For the hatch you might need to form a bubble to cover the top if the battery that might stick out above the planking (you should avoid cutting the spar, battery could sit on top of the spar) just make a smoothly shaped cover.
Best,    Dennis
Offline Rob Roberts
« Reply #4 on: July 06, 2008, 10:36:13 AM »
It has been a few months now has anyone tried one? If you did how was the battery stored?
Offline Mike Palko
« Reply #5 on: July 06, 2008, 11:20:23 AM »
Hi Guys,
   Here is a few pictures of my E-Streak to give you some ideas.
Offline Rob Roberts
« Reply #6 on: July 06, 2008, 11:27:21 AM »
Hi mike would that work with an arf with out turning it back into a kit?
Offline Leester
« Reply #7 on: July 06, 2008, 01:38:03 PM »
Where do you get the Scorpion Motors ??
Leester
ama 830538
Offline Rob Roberts
« Reply #8 on: July 06, 2008, 01:59:51 PM »
innov8tivedesigns.com or gobrushless.com carry Scorpion Motors
Offline Leester
« Reply #9 on: July 06, 2008, 04:54:12 PM »
Leester
ama 830538
Offline Leester
« Reply #10 on: July 06, 2008, 04:56:34 PM »
I've got a John Lowrey WingMaster and profile Stuka lazer cut kits that would probobly be just fine electrified.
Leester
ama 830538
Offline Mike Palko
« Reply #11 on: July 06, 2008, 05:31:00 PM »
Rob,
   That is an ARF I started with. The mods were very simple. I enlarged the engine cutout to accept the AXI motor. Epoxied a 1/8" plywood firewall against the back of the cutout, then faired the firewall in with hard balsa. I notched the leading edge to accept the battery and may have braced the spars. I think I put a shear web between the spars that doubled as a brace and a rear battery stop (I would have to double check). I used two threaded inserts with J-hooks to put a rubber band or two around to secure the battery.
Offline Rob Roberts
« Reply #12 on: July 07, 2008, 03:41:43 PM »
Mike what is the widest battery that will fit? I would like to use the brodak battery I already have, it is almost 2" wide. Thanks for all the help.
  Rob
Offline Mike Palko
« Reply #13 on: July 07, 2008, 04:12:02 PM »
Hi Rob,
   The battery shown is 1.5" wide. If you go past the original seeting just extend it like the electric Super Clown. It looks like the max width you could get in the wing without adding sheeting is 1.75" and that might be tight.
Offline Rudy Taube
  • Ret Flyboy
« Reply #14 on: July 09, 2008, 11:51:23 PM »
Hi Mike,
That looks like an AXI in your FS? Which one is it? What battery size are you using? 3S 2,100  or?? .... TIA for your help
Rudy
AMA 1667
Offline Mike Palko
« Reply #15 on: July 10, 2008, 04:02:02 PM »
Hi Rudy,
   I am using the 2814/10 (because I had it laying around) and a 3S 2100mah pack. With a 8x5 prop it flies ~4.5 second laps (educated guess) on 0.015" x 60' eye to eye lines. The 2814/12 would work just as well..... I am sure you could get away with even less. It only weighs 26oz ready to fly.
Offline Rudy Taube
  • Ret Flyboy
« Reply #16 on: July 10, 2008, 06:47:18 PM »
Thanks for the info. Mike.
One last (? ;-) question: Is the 2,100 enough to give a 5:20 min flight to do the whole pattern?
My FS has the Larry/Stan/Wild Bill Doodlebug tail mod, and now it flys a great pattern with the OS .25.  Again, TIA for your help. :-)
Rudy
AMA 1667
