  • June 18, 2025, 06:25:34 AM
Author Topic: Murphy's Law at work!  (Read 891 times)
Offline John Cralley
« on: August 11, 2013, 12:36:35 PM »
Along the lines of Murphy's Law, I have finally assembled an ARF Brodak Electric Super Clown which I have had in the  queue for a couple of years now. Being essentially cheap I chose not to buy Brodak's overpriced electric component set. What bumped the SC down the queue is that it is setup for the battery to be inserted into a slot in the wing. When I started looking for batteries to fit in the wing slot I found the virtually all 4S batteries were too "fat" to fit so I defaulted to 3S and still most would not fit. Then I happened up on 3S 1800 mah batteries listed on Hobby King USA warehouse that sounded like them would fit fine at $12.53 each! I bought a couple and a motor with a 1300 kv and put the S Clown together. Charged the batteries and gave it a test using a CC Phoenix ESC in Governor High. Wow, I could not get the RPM up and it quickly dropped the battery to 10 volts or so.  HB~> HB~>  I tried a different ESC - same results. I was considering sending the batteries back to Hobby King when I discovered that they were NOT LIpo batteries but really they are LiFe batteries (also called A123 batteries) and 9.9 volts is the nominal voltage for them. Since the ESC was programmed for Lipo batteries it expected to see 4.18 V or so per cell instead of the 3.6 V which is full charge for LiFe batteries. I reprogrammed the ESC and Whee the RPM came up to snuff and the S Clown flies great. I am really surprised that LiFe batteries are selling so inexpensively and in that configuration.  http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=23681  One nice thing about LiFe batteries is that they are not supposed to care if they are stored at full charge and one does not have to mess with discharging them to 50% for storage. A disadvantage is that you pay a weight penalty but for a sport model like the E Super Clown that does not matter too much.
Luckily, the batteries seem none the worse for being charged as Lipo instead of LiFe variety. When searching for batteries I was concentrating on dimensions but you may be sure that I will read ALL the Specs closely from now on!! y1
« Last Edit: August 11, 2013, 02:06:05 PM by John Cralley »
John Cralley
AMA 52183
Central Illinois
Offline Larry Renger
Re: Murphy's Law at work!
« Reply #1 on: August 11, 2013, 05:59:48 PM »
Someone who really knows, please check my info, but i understand that the LiFe batteries can be completely discharged rather than needing a 20% margin, so there is actually no weight penalty.
« Reply #2 on: August 11, 2013, 06:23:20 PM »
Yes Larry, I believe that is correct but I do not know how much the voltage tails off during that last 20%.
Like you say, someone that has data for the voltage curve for LiFe batteries please chime in.
John Cralley
AMA 52183
Central Illinois
Offline John Hammonds
« Reply #3 on: August 12, 2013, 07:33:24 AM »
Hi John,
 I used LiFeP04 packs for a few years when I originally got back into CL. 5 years on they still work. The discharge curve is very flat (Just like the old Nicad cells). But when they do drop off they do it very quickly indeed. Even setting your ESC to "Soft Cutoff" will probably not save you if you are climbing for the 3rd loop of the clover. They are very robust though and during my early flights I only ever damaged 1 cell and that was due to the pack coming out of it's mounting and hitting the motor (No smoke or drama, and the motor continued to run until I switched it all off). But they are heavy and only come in limited capacities. They (As you found) run at much lower voltages than Lipo equivalents and it is worth bearing in mind that when reaching the end of the flight, the amps being drawn can by quite a bit higher than a similar Lipo set up. I have never noticed any degradation despite discharging past 90% on many occasions but that does take you very close to the "cliff edge" of performance drop off. Unlike Lipo's there is no issue with "Topping up" before a flight or leaving charged between flying sessions although for extended periods I am led to believe that storing between 40% & 60% charge is beneficial.
For a trainer I would recommend them every time.
TTFN
John.
BMFA 165249
