  • August 02, 2025, 07:08:19 AM
Author Topic: ESCs  (Read 2428 times)
ESCs
« on: October 20, 2016, 11:04:54 AM »
Been reading threads about ESCs, again.  I just did a Google (well, ixquick) search on "open source ESC" -- the results were illuminating.  Apparently the "maker" community is not treating ESCs as an off-the-shelf item.
If someone out there is wishing for an ESC that's customized to work with control line stunt -- here's a starting point.
Re: ESCs
« Reply #1 on: October 20, 2016, 01:26:43 PM »
Gee Tim, when will you start making yours?
Re: ESCs
« Reply #2 on: October 20, 2016, 01:53:21 PM »
Actually, some of the results that popped up looked like things I could just buy and either use with the right tuning, or tweak a bit.
The quadcopters need to be able to control motor speed pretty tightly, and if they're flying 3D they need to reverse direction to boot -- and they make it all work.  The biggest problem is that most aerobatic quads aren't nearly big enough.
Re: ESCs
« Reply #3 on: October 20, 2016, 02:44:31 PM »
hmmm and aerobatic Quadcopter on control line? Tim, not sure that fits the spirit of the event there, but think about the square corners you could do with that!!
Re: ESCs
« Reply #4 on: October 20, 2016, 04:57:22 PM »
Sigh.  Gotta spell it out for the hix from the stix: if it can do aerobatic quadcopter stuff, then it should easily keep up with an Igor Thang.
Re: ESCs
« Reply #5 on: October 20, 2016, 05:14:29 PM »
Hey  I blew right past the ESC question and went right to making a Quad do the pattern,, and I aint no Hick from the stix,, just cause I live in farm land,,
Re: ESCs
« Reply #6 on: October 20, 2016, 11:26:37 PM »
Given how few trees there are out that way maybe I should have said "stick".
