  • June 26, 2025, 01:10:13 AM
Author Topic: Electric Smoothie verson II  (Read 3850 times)
Offline bob branch
« on: April 12, 2007, 07:16:50 PM »
I've just finished an ARC version of the electric smoothie that Rick Sawicki developed and that I purchased from Frank Carlisle. With the ARC I can get appearance points if they are offered and I ... well, sorry, just didn't like the color scheme of the arf. The finish is in Ultracote with monocote trim applied with the windex method (ie no heat.) The spinner will turn matching color of the plane this weekend. Power is the Axi 2826/10 with phoenix 45 esc. Timer is zigras. The new one with the dip switch power setup described in Control Line this last issue. Battery is polyquest 4000 mah 4 cell lipo. This is a departure from Rick and Frank's versions which Rick designed to be an entry level setup that would fly the pattern. I've also converted to Govenor mode on the esc. Rick is duplicating my setup on his smoothie for this season and since we are only about 2 hours apart we are planning some development sessions together. Right now prop is Zinger 11X6 at 9800 rpm. Lines are 62 ft and lap times 5.1 sec. Line tension is strong throught the pattern. I'm planning on working with different props and different motor speeds early on with the new controler. The current setup is drawing 3000mah out of the battery and temps are all very reasonable.
One of the real advantages of a smoothie for getting your feet wet is the big space available above the wing for the battery to slide back into. You can see the battery in the pic and about half of it is above the wing. This allows a normal balance point without adding weight. Bout the only thing not self expanatory in the pics is the latch for the hatch which is a BVM latch used in RC jets. It took less room than anything else I had on hand. If I were doing a full build I would use magnets instead. They are working out great in RC.
Offline fernando torres
Re: Electric Smoothie verson II
« Reply #1 on: April 12, 2007, 08:24:31 PM »
I noticed a metal motor mount. Are you using plywood doublers to attach it?
Fernando
FET
Offline Mike Palko
« Reply #2 on: April 12, 2007, 09:40:21 PM »
Bob,
   Very nice, I like the scoops  ;D. What is the ready to fly weight? Did it come out lighter than the ARF version?
   Not to get off track, but I don't believe I know about the "windex method".
Offline bob branch
« Reply #3 on: April 13, 2007, 06:10:59 AM »
The weight ready to fly is 51.3 oz. Sorry, I did not weigh the arf but since the finish method is the same i expect its within the normal weight range of the ARF. Would not expect it to be lighter or heavier.
The windex method is very simple and fun. The primary covering can be any material. I use Ultracote just because I like its working properties and end results better than any of the other films. It has a low stick temp, a very wide range of shrink temp (ie it can shrink alot more than others and you can control what you need better) and it bubbles up less than monocote. Very much better over solid surfaces. The trims must be Monocote or Black Baron film. Ultracote will not work here. Cut your trim pieces. Spray the surface they are going to go on with Windex, and apply the film like you would a slide off decal. You can move it until you are happy with its position. If the Windex starts to dry and it doesn't move and you still are not happy, shoot it with windex again and it will move. Once you are positioned use a credit card to squeege the excell windex from under the trim piece. I find it a good idea to watch it a bit to make sure no areas lift slightly along an edge which it will do only if you do not have the piece straight as cut.  Apply all your trims and let it dry for a day. The use monocote adhesive solvent on a cotton swab and go along all the edges with it. It will seep under the film strongly activate the adhesive, and its there for the duration and fuel proof. As soon as you apply this solution you must wipe off the excess. If it dries you will have alot of work to get it rubbed off. When you wipe it off you will have to do some buffing to get it all off. This results in a higher sheen on all the materials than they normally posses! This is the method the RC folks use for doing things like flags with the folds and shadows showing thru from behind (transparent color on top, transparent shadow beneath.) If you tried to do it with heat all the different temps would just make it a shriveled mess. Also applying a trim color over another color will cause bubbles between the materials which are very difficult to control. And lastly applying straight line trims with heat will result in non straight lines. I know this sounds so dumb it must not work. But it does. Don't know about other solvents for the windex. Every time I or anyone else has written about this everyone seems to go off on "well can I use ...." I don't know. Windex just works. BTW, I find it a good idea to clean off the surface with air, a tack rag, and the windex before applying the trims so you don't get dust specks showing thru.
Bob Branch
Offline bob branch
« Reply #4 on: April 13, 2007, 06:19:40 AM »
Fernando
Sorry, I linked to Mike's question first. Yes, the motor mount is just bolted to the doublers in the plane. The original engine bearers and front bulkhead were dremeled away. I recessed the bolts into the balsa sides since they would crush. A washer is inset under the bolt head and the bolts (6-32's) are threaded into the engine mount which is aluminum. No other structure is used or seems to be needed judging by two years history of the previously flying planes. One thing I should mention is that I ground out some of the bulkhead on the belly pan and under the wing leading edge to allow air exit from the engine-battery compartment. There are two large openings in the belly pan for air to draw out.
Bob Branch
Offline frank carlisle
« Reply #5 on: April 14, 2007, 01:32:00 PM »
It looks good Bob.  Nice color choices. Is that slide pin cowl hold down spring loaded?
I missed you today in Toledo. I hung around the Brodak booth for awhile.
Frank Carlisle
Offline bob branch
« Reply #6 on: April 14, 2007, 04:14:29 PM »
Frank
Yes the latch is spring loaded. A little strong for my liking though.
I didn't hit the Brodak booth til after lunch, did the other side in the morning then the side the brodak display was on.
bob
« Reply #7 on: April 14, 2007, 05:25:48 PM »
How about posting a picture of how you've arranged the spring?
I left for home around one o'clock. Got lots of goodies. Saw Art got the engines for the twin from him. I'm geeked and ready to start flying.
Frank Carlisle
Offline bob branch
« Reply #8 on: April 14, 2007, 07:52:29 PM »
Frank
These pics will show the final arrangement of the spring latch mechanism. At first I glued it outside the hatch. That would be accepted ok in RC but looking at it it just didn't keep with stunt norms. So I cut it off. Of course it was glued on with thick CA so the wood came with it. So I mounted it on a new piece of wood to plug the hole and allow me to sand it fair and recover the area. Pic #1 shows the top of the hatch from the outside. Pic #2 shows the mechanism on the inside. BTW, I cut off 2 coils of the spring after the pic and that took some of the preload off the spring and made the latch more workable. Pic #3 shows where the pin is received under the turtle deck. The top hole was where it latched when the mechanism was external. The lower hole is formed by two pieces of motor mount hardwood then Ca'd on the inside of the hole to resist wear.
Bob Branch
« Reply #9 on: April 15, 2007, 07:03:44 PM »
Thanks for the pics Bob..........good job you did there.
Frank Carlisle
« Reply #10 on: April 15, 2007, 10:58:43 PM »
A quick note on the monokote windex method,, in my experience, it is a very good idea to let the trim peices sit 24 hours after you windex them on. this allows any residue windex to be completely evaporated before you seal it down, If you dont you may get bubbles from the traped windex when you set it in the sun.
Offline bob branch
« Reply #11 on: April 16, 2007, 05:55:59 AM »
Mark
I aggree. And we should point out that you do not do the monocote solvent application til that time has elapsed or you  could entrap the stuff. Thanks for adding your comment Mark.
Bob Branch
« Reply #12 on: April 29, 2007, 07:30:33 AM »
I flew Bob's Smoothie yesterday and also watched him fly it several times. The 4000 mah 4 cells really added the power . I could feel a dramatic improvement over the 3700 mah 3 cells I had used originally.
He has the plane trimmed out pretty good and I think he'll be pretty competitive with it.
Hey Bob thanks for the ride!!
Frank Carlisle
Offline CharlesF
« Reply #13 on: June 06, 2007, 06:59:51 AM »
Here in the UK we use Fairey Liquid (washing-up liquid) and water to stick the trim. The method really does work well. Certain paints also work OK over Ultracoat (Oracover) too.
I used small magnets to attach the cowl of my recent Thunderbird. They are 6mm x 2mm and once you get the method sorted out work really well. Very positive and strong - and invisible too!
I don't know how to attach a photo here. If I did know, I'd show it.
Charles
Canterbury
UK
Offline bob branch
« Reply #14 on: June 06, 2007, 09:55:18 AM »
Just as an interesting aside, due to a problem with my pampa modern stunter I wound up flying the electric smoothie in my first contest in pampa advanced at Flint, MI a few weeks back. I wound up taking seocnd with it in advanced stunt and 3rd in classic stunt.
I like the magnets, and have started using them in my RC planes this year. I was going to use them with the smoothie, but it was just expedient to do a different latch on the hatch since I was transfering it over from Frank Carlisle's electric smoothie. I wanted some of his original plane in this one.
Bob
Offline Maurice Bishop
« Reply #15 on: January 18, 2008, 11:11:00 PM »
Bob Branch
Any idea what the 'active ingredient' might be in Windex that works with the film adhesive? I am trying to identify a Windex equivalent in the UK.
Much obliged
Maurice
Good judgment comes from experience. Experience comes from bad judgment.
Offline bob branch
« Reply #16 on: January 19, 2008, 06:57:48 AM »
Maurice
I haven't got a clue as to what the active ingredient in the windex is. Windex is the most popular glass window cleaner over here in the states. Its been around since forever. My guess is if you try the best name known similar product over there that has been there the longest you will have something similar. After it has dried well I usually use heat to seal down edges on solid surfaces like leading edges and flap edges. The monocote solvent you will want to apply very sparingly. Don't soak a full size Q tip with it as you will have too much and it will start to run around too much. Just let it soak under the edges a few minutes then gently wipe and polish it off. I'd polish parrellel to the trim lins so you don't risk lifting it while the solvent under the edge is still setting. But you do need to polish if off before it dries or its a bear to get off.
Good luck,
bob branch
Alan Hahn
« Reply #17 on: January 19, 2008, 10:06:04 AM »
Maurice,
I am not sure if you saw this over on SSW, but the 8th reply gives the formula of Windex. What is interesting is that that original thread, like this one, were just "resurected" from the past!
Here is the link to the Windex thread on SSW.
http://www.clstunt.com/htdocs/dc/dcboard.php?az=show_topic&forum=103&topic_id=254521&mesg_id=254521&page=#254565
Note added: If you are "Shobosh", then you are the one that pulled it out of the past! But the formula is given in my link above.
