  • July 14, 2025, 06:18:30 PM
Author Topic: E-Pinto 1/2A project?  (Read 1168 times)
Offline Duke.Johnson
« on: October 31, 2013, 10:51:34 AM »
So, I'm putting a bunch of thought into the 1/2A Pinto.  I'm thinking of going electric with it.  I searched and found one set up listed.  Has anyone else tried this? Did you have to lengthen the nose or add weight to balance? Any suggestions?  I really like this plane, but don't want to finally build it, go electric, then it not fly well/right.
Re: E-Pinto 1/2A project?
« Reply #1 on: October 31, 2013, 12:14:51 PM »
Duke,
One thing when converting from IC to EL you need to adjust the old tank compartment to allow the battery to be moved (mostly rearward) to get the CG right. Many times people just stick the battery were the old tin tank went and wonder why the ship is so nose heavy and then have to add significant tail weight. What has worked for me in my electric Stuka was to remove the top part of the rear firewall to give access to move the battery back over the wing. I have found that most of the time you need to be able to put up to 1/3 ish of the length of the pack back over the leading edge of the wing to get the CG at the 12% - 16% point (common for the classic era ships). I use a strip of Velcro on the bottom of the battery to hold it fore and aft and two Velcro straps around it to keep it down. Make sure you allow about 1/8" for clearance around the battery to allow for the pack to swell a bit. In my Stuka I didn't do this and can only use really new packs, once the swell (after about 50 flights) I can't use them even thought they are good packs the additional depth won't fit inside the fuse. Good luck keep us posted on the setup you use and how it works out.
Best,      DennisT
Offline roger gebhart
« Reply #2 on: October 31, 2013, 05:27:28 PM »
Hope this keeps going as I have been thinking along the same lines with a 1/2a cobra. I got a lot to learn.  rog
« Reply #3 on: October 31, 2013, 08:54:25 PM »
In the List your Set-ups thread there are at least 2 1/2A Pathfinders (Andy Borgogna's & mine) with power systems that would be outstanding in the Pinto.  I used the PF to prove-out the Brodak EPS-10 power package, Andy took a similar starting point and added a KR timer.  I am also using this system on a Wee Duper Zilch OTS (251 sq in) and it is great there too.
As Dennis T said, you should be able to put the battery where the tank would have gone.  On the WDZ I use a top hatch, with the ESC exposed on the bottom of the fuse.  Had to notch out the wing LE because of the short nose but the balance is good.  I would use a top hatch on the Pinto too; its very convenient.
BTW, if Pinto doesn't have one already, make sure you modify it for a 3" bellcrank.
Offline ericrule
« Reply #4 on: November 01, 2013, 09:57:42 AM »
Both Larry Renger and Mike Griffin currently have Electric Pinto's on their building boards. I converted this model to a Profile to make the conversion easier and ran off a laser cut kit for each of them.
The reason for going to a profile was so that we did not have to take a lot of time reworking the built up fuselage. Since the darned thing is only 1" across we didn't want to do all of the work involved in a rework so that motors and batteries would fit properly. In addition just hanging the stuff on the profile fuselage makes cooling a non issue (even less work involved in the conversion).
Since neither of the guys has finished the building there has been no test flights done. Once I get reports from them we will know where things like the battery have to go in order to get a decent C/G. Once that is computed we should be able to go ahead with converting the built up version to electric.
Eric Rule
« Reply #5 on: November 01, 2013, 11:38:42 AM »
Thanks guys! This is helping a lot.  I don't know if I'm interested in a profile version, one of the reasons I'm building this is to better my building skills to build another bucket list plane, the Yates Dragon. And I'm thinking of putting it in beginner stunt next year against my oldest son's Oriental.  I might even paint it the same color scheme. VD~ S?P  So I need to look for a set up that fits in the fuse? Is this going to be hard to find?
Offline ericrule
« Reply #6 on: November 02, 2013, 03:36:22 PM »
OK Duke:
We've already got a drop in electric conversion for both the Madman and the Dragon.
The Pinto is a much more difficult conversion. This is due to the fact that the fuselage while built up is only 1" wide at the motor area. Not only is it narrow but the total height of the fuselage will not allow you to run a battery inside even if it is laid on it's side. This simple fact makes it necessary to redesign the fuselage so that the electric components, especially the battery, will fit.
In my opinion due to the work involved it would be far easier to simply design a new model than to rework the Pinto (which is just a 60% sized Oriental). If you were going to go to all that work I would increase the size a bit and install a .15 glow powered equivalent Electric system.
Eric Rule
« Reply #7 on: November 02, 2013, 11:03:35 PM »
If it can't be done with the 1/2A size, I'll just put a glow engine in it.  Has anyone converted the stock fuse to electric?
