Electric Stunt => Gettin all AMP'ed up! => Topic started by: Paul Allen on September 01, 2010, 03:27:37 PM
Title: E-Max / Arrowind
Post by: Paul Allen on September 01, 2010, 03:27:37 PM
Guy's
       Someone commented in an earlier post that E-Max and Arrowind were the same motor is this true?
Paul Allen
Australia
Title: Re: E-Max / Arrowind
Post by: Russell Bond on September 01, 2010, 07:00:00 PM
Yes, i've bought some Emax motors from Himodel.com.
Same as the Arrowind, just a different sticker.
Post by: Keith Renecle on September 01, 2010, 11:12:12 PM
That is correct, I got this info directly from Arrowind. The E-Max factory is Yin Yan Model Tech Manufacturing in Shenzen, China. I've been using quite a few of the E-Max 2820 and 2826 motors with zero failures so far. I have heard of a few where the magnets came loose, but you can always strip them when you buy them and check this out.
I use the 2820 in my .40 engine size stunters on 11 x 5,5 props, and even 12 x 6, and the motor is hardly warm after the flight. In hot weather around 32 degrees C, I have felt that they get a little warmer. The air just seems to get through very well for good cooling. The other day I was testing to see what rpm I would get with a finer pitch pusher prop, and I was a little lazy to change the motor wires to reverse the rotation. The motor got hot quickly, so I reckon that it's due to good airflow through the casing. The motors tend to have a bigger diameter instead of longer length like the Scorpions, so maybe the air goes through easier?? This could be an advantage for bigger diameter as opposed to longer length. I've read the arguments about torque for those two designs, but cooling is a real important factor as well. Ask me how I know!!
Keith R
Post by: Paul Allen on September 02, 2010, 02:59:55 PM
Thanks guy's for replying,I came across an online hobby supplier
in Perth, Australia who had a small number of E-Max motors.
Paul Allen
