  • July 17, 2025, 08:11:29 AM
Author Topic: E Legacy conversion  (Read 4086 times)
Offline Gus Urtubey
E Legacy conversion
« on: December 18, 2014, 05:01:11 PM »
I just finished up my electric conversion of a Legacy ARF. There was way more work than I expected. In
addition to the conversion, I made it completely take apart while changing the landing gear wires ( the originals were too soft )and I installed Dave Brown pushrods.
I had to shorten the nose and move the battery inside the wing to bring the CG as indicated by the designer.
It came up to 64 oz with battery ready to fly.
TP 2700 5S , Plettenberg 20-16, Shulze F2B ESC and Aerolectric TP-1 processor.
I found that it was a lot of work , probably because it was my first time completing a proejct like this one. In hindsight it would've probably been easier to build a new fuselage, which is what I will do next time. Im now just waiting for Spring to put in the first trimming flights.
Offline Gus Urtubey
Re: E Legacy conversion
« Reply #1 on: December 18, 2014, 05:03:20 PM »
More pics
James_Mynes
« Reply #2 on: December 18, 2014, 05:27:22 PM »
I like it!
Offline John Tate
« Reply #3 on: December 18, 2014, 10:17:11 PM »
I like what you have done there.
You mentioned that the model is a take apart.
How is the wing installed?
A picture would be great.
« Last Edit: December 20, 2014, 02:46:11 PM by John Tate »
« Reply #4 on: December 19, 2014, 08:23:27 AM »
I like the looks of the plane,  but, I would have made the opening for the air out lets mucho bigger than the inlet.   Of course this is E power and not IC like I use all time.
Offline Gus Urtubey
« Reply #5 on: December 19, 2014, 09:33:40 PM »
Thank you guys,
                         I took some pics of the take apart. I always build two panel take apart wings but this time the wing was already built for me.
Merry Christmas !!!
Offline John Tate
« Reply #6 on: December 20, 2014, 02:52:26 PM »
Great pictures. I like the way you did the take apart. The model should serve you well.
Offline Crist Rigotti
« Reply #7 on: December 20, 2014, 06:54:23 PM »
I see some wiring going to the aft most bottom cutout.  What's there?
Nice job!
Offline Gus Urtubey
« Reply #8 on: December 20, 2014, 08:05:25 PM »
The wiring goes to the timer or processor . Kim's processor has an electronic needle to set RPM among many other features. We installed it behind the wing to have weight in the aft. , and to be away from the prop.....
« Reply #9 on: December 20, 2014, 08:23:44 PM »
Ahh, that explains it perfectly.  Thanks.
Online Don Jenkins
« Reply #10 on: December 22, 2014, 06:53:58 AM »
Gustavo,
Nice job, but you don't have to wait for Spring for trim flights, bring it with you on your next trip to NC and I'll meet you at the field.  I went flying two days ago, although I was the only one at the field, it was calm, overcast and 48 degrees.  Come on down!
Don
Offline Gus Urtubey
« Reply #11 on: December 22, 2014, 06:52:28 PM »
Thank you Don, hopefully soon ... :)
