  • June 21, 2025, 06:24:48 PM
Author Topic: E-Hacker and Electric Combat  (Read 1341 times)
« on: February 04, 2011, 07:42:54 PM »
I've had several people, Ed Bridant among them, tell me about converting the Li'l Hacker to electric.  So I started researching and found what I think is the right stuff.  WAG calculations gave me 140 watts in, ~110 at the prop.  That led to the first big decision.  There is no way to get that kind of power out of a large battery.  Even 1000 mah is on the heavy side for real performance.  I also wanted to fit it into the wing with the flat side forward in case of a crash, limiting the battery to about 1in. wide.  But E-Flite came to the rescue with a 3 cell, 30C, 800mah battery that weighs about 58 grams complete.  I dug up a Turnigy 2820/1650 motor, rated at 16 amps.  At that power draw I figured a bit over 3 min.
Test runs in the winter here confirmed it pretty nicely.  It turns a 7/5E prop around 15,000 rpm.  At three minutes the motor is barely warm.  At 3min. 20 sec. the Castle 25 shuts it off.
I can hardly wait for the weather to break to try it out in the air.  The total power package weighs a bit less than 90 grams, just about 3 oz.  That compares pretty favorably with a TD or Norvel at 1.5 oz. with another 1-2 oz. of fuel.  That big prop sure does move a ton of air.  It blew pieces of foam and other stuff off the bench and all over the place.
Re: E-Hacker and Electric Combat
« Reply #1 on: February 04, 2011, 10:46:56 PM »
What do you reckon it would take to make an electric F2D practice plane?
Offline Keith Renecle
« Reply #2 on: February 05, 2011, 12:58:57 AM »
Have a look at this on Claudia Kehnen's site; http://www.fesselflug.eu/html/f2d_-_elektro_combat.html
There are some videos to look at as well. My German is not too delicious, so I clicked on the  translation button and the word "combat" came out as "fox-hunt!" Maybe it meant Fox 36X??
keith R
Keith R
« Reply #3 on: February 05, 2011, 01:57:46 AM »
Cool.  Thanks.  I see they use a folding prop.  Has anybody pursued the idea of stopping the prop in the horizontal position by some electrical trick?
Offline Robertc
« Reply #4 on: February 05, 2011, 10:18:10 AM »
"Has anybody pursued the idea of stopping the prop in the horizontal position by some electrical trick?"
That is what one of the electric speed guys was working on a while back.  Maybe someone knows who that was
and the results.
« Reply #5 on: February 05, 2011, 07:15:35 PM »
I'd go for about 500 watts to the motor, aiming for 3 min.  With a 4 cell pack(14.8v) it would draw about 33 amps.  The 1500-1700mah battery should run around 3 min+. Amps=60*Ah/runtime.  A motor similar to the AXI2808 with a Kv around 1400 weighs about 77gr.  the battery about 160 gr.
speed control 15 gr.  radio receiver8 gr.(you don't want to use timer for experimenting!) All up power supply would be about 260gr.(F2D engine, mounts, muffler, shutoff and fuel weigh about the same).
The outrunner motors are pretty sensitive to crash damage.  Mounting the motor with the bell facing forward is asking for trouble.  Any kind of ground hit can knock the magnet can out of alignment or bend the shaft.  Much better to mount the motor with a flat plate mount on the end where the wires come out and mount the can inside the mount or plane.  On most motors the shaft can be slid for and aft so it comes out of either end.  A little more complicated though.
« Reply #6 on: February 06, 2011, 10:44:04 PM »
I've been fooling around with this for a while in between making my governor system work, and I've tried the MVVS 2,5/1480 motor that is an IN/OUT runner. This is a high quality really tough design with the drum inside the casing, and you won't bend the shaft easily. I tested it with a 3-cell pack but it does not have enough rpm. I'm thinking that I need to try it with 2 x 2 cell packs because the 4-cell small packs are hard to get. The motor's weight is higher than normal at 109 grams but that's because of the extra casing etc. The connections at the back are also nice. My first test was using a standard Russian type wing, and the CG was too far back, even with the heavy motor, so I need to design a new wing especially for the electric stuff.
I used my governor timer, not because I really wanted the constant rpm, but because my system shuts down when the prop rpm goes lower than a pre-set amount, or in the case of hitting the deck. You connect the extra wire from my timer to any one of the motor wires, so the rpm is monitored all the time. I even use this on my 1/2A trainers because most beginners hit the deck all the time and you don't want to burn out esc's and motors all the time. I just need to find a little extra time to build a new wing, and then I'll try this again.
Keith R
« Reply #7 on: February 09, 2011, 06:17:21 PM »
Thanks, folks.  Is there a US supplier for the MVVS 2,5/1480?
« Reply #8 on: February 09, 2011, 10:08:25 PM »
If you can't find a source locally, then Alberto Parra is most likely your closest source http://www.clubtamaran.com/electricos2.htm
Keith R
Keith R
Offline Jason Greer
« Reply #9 on: February 12, 2011, 09:04:07 AM »
It seems Hacker has a new esc/motor combo that is not sensorless.  Of course this system is much larger than required, but it does have the ability to stop the prop at a specified location.
http://www.heliplane.net/2011/02/toyfair-2011-%E2%80%93-hacker/
Hacker C50 Sensored F3A Competition Power System
Hacker showed the new Senstrol 120 brushless airplane motor and controller combo. Coming with what they call Constant Power Management the controller simply holds the RPM adjusted by the transmitter stick irregardless the flight situation the plane. For example the plane is flight into a loop then the controller holds the RPM by putting more power on the motor and also holds the RPM when going downwards again by given less power on the motor. F3A pilots who need this constant speed flight situation will welcome this. Also, when turning the motor off the prop is positionable in any position you want and it stays there until you start the motor again. Hacker achieved this by having a 4096 step encoding system for the motor and fully automatic real-time variable frequency and phase sequencing calculation. The system is fully RPM controlled giving proportional RPM output with stick movement. The system is made around Hacker's C50 line of brushless motors with KV rating variants available when the Senstrol system is finally available.
El Dorado, AR
AMA 518858
« Reply #10 on: February 12, 2011, 09:56:17 PM »
Wow.  Thanks.  That looks really cool.  It's probably made specifically for Phil's plane from the looks of the name.
