  • June 20, 2025, 10:52:50 AM
Author Topic: E-Flite timer  (Read 2245 times)
Online Larry Renger
E-Flite timer
« on: August 06, 2010, 10:14:24 AM »
E-Flite has a 3.2 gram timer for under $10!  Has anyone tried this?  It looks like just the ticket for small e-flying.   http://www.horizonhobby.com/Products/Default.aspx?ProdID=EFLA172
Offline Igor Burger
Re: E-Flite timer
« Reply #1 on: August 06, 2010, 10:42:24 AM »
Larry, really small eflight need something even smaller ... for example that on picture it has only 0.8g  VD~
Online Larry Renger
Re: E-Flite timer
« Reply #2 on: August 06, 2010, 10:57:14 AM »
Interesting!  I presume it is a homebuilt design.  Can it be built by anyone?  My electronic skills are on the level that I have never soldered a resistor in backwards.   :-\
Offline Rob Roberts
Re: E-Flite timer
« Reply #3 on: August 06, 2010, 04:47:38 PM »
Offline Rudy Taube
  • Ret Flyboy
Re: E-Flite timer
« Reply #4 on: August 06, 2010, 05:49:42 PM »
Hi Larry,
We are very fortunate in ECL to now have a rich plethora of timers. Just a few years ago we had only one or two, now we have many. We have them from Canada, the USA, South America, Europe, Japan, and I'm sure there are many more that I don't know about.
Igor has been one of our pioneer's in ECL and the timer makers of today are standing on his strong shoulders. I think his timer weight is somewhere between Hydrogen and Helium on the periodic table, they are really light! I think he uses them in his supper light indoor CLPA planes. You two will get along well.  :)
If it were not for the timer pioneer's like Igor, Kim, and the creators of the JMP and Z timers, we would not have the wonderful ECL power systems we have today. :-)
I am a big Horizon, E-Flite fan and use many of their products in my ERC flying. But in this case I think Will Hubin has made the timer that is going to be hard to beat in the market place.
I think you will like Will's new FM-9 timer for your small and large planes. Will has taken most of the parts off the timer and put them into his programmer. This makes his timer weigh almost nothing, it's very small, and costs only $10 to $12 depending on if you need/want the remote button. It is a FULL feature timer that has everything we could ever ask for. And he can add almost any features you can dream of. It allows you to make very short trim flights if you want, replacing the need for an RC assist. ;-)  You are welcome to use my programmer for your setup.
If you receive your PAMPA SN "on-line" then you can go to the E-Sunt column and see the 3 page write up of Will's new timer now. Or wait till your issue arrives in the mail.
I suggest that you contact Will and get any info. you need. I promise that you won't be disappointed with his timer. :-)
Regards,  H^^
« Last Edit: August 07, 2010, 03:59:53 PM by Rudy Taube »
Rudy
AMA 1667
Offline Roger Anderson
Re: E-Flite timer
« Reply #5 on: August 06, 2010, 06:49:58 PM »
Hey Rudy, I agree that Will Hubin's FM-9 timer is the cat's meow.  The FM-9 timer is very small & light and is extremely easy to program.  I presently have the only programer in our area but it is available for everyone around here to use.
Best wishes and good safe flying,
Roger Anderson
Offline Will Hubin
Re: E-Flite timer
« Reply #6 on: August 06, 2010, 08:35:41 PM »
I had the pleasure of building and flying E-flite's PT-19 (reported on in the February 2010 issue of Flying Models). It came with the $10 E-flite timer. It only allows for flight times in even minutes, it starts up almost immediately after you set the number of minutes, and it doesn't provide a useful warning at the end of the flight time--so it wasn't ideal for a model in which I was trying to close the canopy while the motor was running or one for which you're planning to fly the whole pattern. But it did work and might be quite acceptable for (especially) a free-flight model. (I talked with the person who designed this timer, in the early days of eC/L; he sold the design to a Chinese company that is making them now.)
I do provide Igor's timer (with his concurrence), as the FM-0a (on a circuit board) and as the FM-0b (3-pins soldered to the chip, as he pictured it). It is programmable for both flight time and flight power (switch off the power between the first and second seconds after turning it on; that puts it in the programming mode) and it provides a built-in 30 second delay before flight power is given to the ESC. (I'm charging $12 for one and $18 for two, including S&H.)
Offline Igor Burger
Re: E-Flite timer
« Reply #7 on: August 07, 2010, 01:32:26 AM »
Larry, it is programmed single chip computer. So it can be built, but you need that program. Howevere I do them really home, but they are used by all indoor flyers here around and yes, we use it also in large models. Newest version is programmable (on user level) by box sold for programming Jeti spin ESCs so those people who use my setup also use that timer together with jeti box and jeti spin.
BTW it is programmable in 64 programming steps with possible inputs from outside and outputs, with loops, timeouts, interupts etc, so it is used also by FF slope flyers for "bunt" starts etc :-)
look here:
Offline Igor Burger
Re: E-Flite timer
« Reply #8 on: August 07, 2010, 01:38:33 AM »
 ;D ... Will until we are on opposite sides of ocean, and since shipping is close to price of the device, we not need to worry about it :-)
So we can be both rich from those 15$ (or 15E which I charge for timer)  VD~
I will sale them 1000 and will go swimming to Bahama one day  LL~
Offline John Cralley
Re: E-Flite timer
« Reply #9 on: August 07, 2010, 11:54:46 AM »
Larry,
I was writing a reply when I was hit by a BSOD and lost it (that was a couple of days ago).
I second what Will says (and Igor). Will's timers are inexpensive and easily set up to provide what is needed for E Control Line. I do not have the FM-9 system because I already had several of Will's timers when he came out with that timer/programmer system. Maybe if Will was taking trade ins for credit I would send him a bunch back and go FM-9 (just kidding Will).
There are other timers which are more expensive but which work quite well (have a couple which are now unused and in my spare box). These are not as easily programmed (Igor's may be an exception using the Jeti programmer).
My advice is don't try to save $10 on a timer that is clearly inferior.
John Cralley
AMA 52183
Central Illinois
Offline Andrew Borgogna
  • Andy
Re: E-Flite timer
« Reply #10 on: August 07, 2010, 12:26:12 PM »
I took the following from the tech manual for this product.   Note the line in red.  You have to set the flight time every time you fly.  I find this alone makes the unit not usable for me.
Andy
1. Pushing the start button and holding it down will cause the motor to run for a split second at minimal throttle.
As you continue to hold the start button down the motor will run and stop, run and stop, run and stop every
few seconds. Each of these run and stop periods dictates one minute of flight time. Three starts and stops
would equal three minutes.
2. When you come to the number of cycles (equaling the number of minutes) you would like to fly, release the
start button and the motor will start within 5 seconds and will achieve full throttle as set by the potentiometer
within 3 seconds. Once at full power the motor will run for the specified period of time.
3. We recommend if this is the first time you have flown control line or at least the first time in a few years, you
might start at either 1 or 2 minutes.
4. You will need to set the timing for every flight once you plug in the battery.
Andrew B. Borgogna
Offline Rob Smith
Re: E-Flite timer
« Reply #11 on: August 07, 2010, 10:17:39 PM »
I've used the E-flite timer a lot and while it is a simple to use device it has its faults. If your running a controller in a normal mode (airplane) things work well but I don't like the shut down program either. I'd rather just have the motor stop and stay stopped. Also, this timer does not work well with a Castle controller in the Set RPM mode. Works poorly when trying to shut down at the end of the flight. I've since moved on to a couple of Wil's timers made for the "Set RPM" mode. Much better!
Rob
