My E Flite 32 motor seems to be maxed out at 8800 rpm. I'm not sure if the motor has a problem or not. I'm running a 13 X 6.5 APC pusher prop with a 5S battery. Castle 75 Ice ESC and a Hubin FM-9 timer. I noticed in the "list your setup" that some guys with the E Flite 32 were running a 12" prop, some were using a 13" prop. We thought maybe the batteries were weak, but we tried other newer, more powerful 5S batteries with the same result. Is anyone out there running an E Flite 32 on a 13" prop and seeing higher rpms?
