  • July 12, 2025, 10:24:56 AM
Author Topic: E Flight Q  (Read 1064 times)
E Flight Q
« on: September 10, 2012, 07:48:53 PM »
blank
« Last Edit: September 05, 2021, 09:59:40 AM by Motorman »
Re: E Flight Q
« Reply #1 on: September 10, 2012, 08:43:17 PM »
depends on your timer - most give a drop in RPM about 5 seconds before cut - followed by a burst of higher RPM to get your landing speed up.
Re: E Flight Q
« Reply #2 on: September 11, 2012, 08:34:38 AM »
If you have a timer on the set up, then you need a stop watch on you to tell the time left.
Offline John Cralley
Re: E Flight Q
« Reply #3 on: September 11, 2012, 11:47:42 AM »
What Wynn says. All the timers I know about give an RPM bleep a few seconds before cutoff.
You can also invest in a small "talking timer" which count down minutes then every ten seconds and finally second by second. The one I have will clip on your shirt pocket.
John Cralley
AMA 52183
Central Illinois
Re: E Flight Q
« Reply #4 on: September 11, 2012, 09:39:19 PM »
interesting.....  I know that my flight time is always 5:50 (that how it sets) I know that I have about 5 laps after the completion of the clover before i get the end of flight RPM signal -
no stopwatch needed
