  • June 22, 2025, 02:55:41 AM
Author Topic: Plettenberg Orbit 15-24  (Read 3382 times)
Offline BYU
« on: November 05, 2017, 12:54:33 PM »
I have done my best with search but come up blank so excuse the question (again) if it has already been covered.
I am looking at Pletts and wondered if anyone has used the Plettenberg Orbit 15-24?
Q? Will it work for our purposes and what weight size of plane would it work with?
Thanks for any constructive answers
Offline pmackenzie
  • Pat MacKenzie
Re: Plettenberg Orbit 15-24
« Reply #1 on: November 05, 2017, 01:08:00 PM »
I am using the 15-20 on 5S in a Vector 40, Igor's 11x5 prop and governor mode (no boost).
Pretty sure Paul Walker runs the 15-22 on 6S with Igor's active timer.
15-24 Kv might be a bit too low, unless you plan on running a larger prop?
Pat MacKenzie
MAAC 8177
Offline BYU
« Reply #2 on: November 05, 2017, 01:12:34 PM »
Pat MacKenzie
Thanks Pat, so probably not ideal then?
Offline pmackenzie
  • Pat MacKenzie
« Reply #3 on: November 05, 2017, 01:21:38 PM »
Wait and see if anyone else chimes in, PW in particular  :)
The 15 series is a very good F2B motor. Pretty sure Paul tried just about everything else, and came back to Plettenberg in the end.
MAAC 8177
« Reply #4 on: November 05, 2017, 02:40:17 PM »
The Stunt News Contest Results section is The source for who’s flying what, at least for contests run by conscientious CDs of good moral character, who file complete reports.
Offline BYU
« Reply #5 on: November 06, 2017, 05:49:01 PM »
So? can you point me in the direction of a relevant CD of "good moral character" who can answer the question posed?
« Reply #6 on: November 06, 2017, 10:59:49 PM »
North, I should think, although the undersigned is not currently in the same place as the data. The upcoming SN issue will have three contests with the requisite information, one having it a tad lower on the list than you may expect.
« Reply #7 on: November 11, 2017, 08:11:13 PM »
I am back at Stonehedge now and can report that I've seen two instances of 15-series Plettenbergs being used for stunt: Paul Walker's 15-22 and Uncle Jimby's 15-20.
Offline BYU
« Reply #8 on: November 11, 2017, 09:26:52 PM »
Good to know, thank you for the info. It looks like the 15-24 is for slower rpm and bigger props and is not used by the “professionals” or Paul.
Offline jose modesto
« Reply #9 on: November 11, 2017, 09:47:24 PM »
Can you post the KV of the Platt 15-24
Jose modesto
Offline pmackenzie
  • Pat MacKenzie
« Reply #10 on: November 11, 2017, 10:00:06 PM »
Jose modesto
620 rpm/volt
http://www.plettenberg-motoren.net/index.php/en/plettenberg-motors/plettenberg-brushless-motors/orbit/orbit-15
15-24 on 6S would be about the same RPM as my 15-20 on 5S, so should work fine in governor mode.
No big advantage to this unless you can find a 6S battery that weights the same as the TP 5S 2800 :)
MAAC 8177
