  • June 18, 2025, 11:51:18 PM
Author Topic: 12x6EP vs 12x6E APC ???  (Read 1510 times)
« on: June 19, 2014, 09:01:25 PM »
Anyone know what the difference between these two props?
One is a E the other EP. Side by side i see no difference.
Rick_Huff
Re: 12x6EP vs 12x6E APC ???
« Reply #1 on: June 20, 2014, 05:26:31 AM »
Paul,
I'm pretty sure that the "EP" designates Electric, Pusher (cw rotation, when viewed from the front of the plane).
Rick
« Reply #2 on: June 20, 2014, 05:38:59 AM »
Hi Paul
First in big generalities: the "E" props are normal RH CCW rotation, the "EP" props are reverse/LH/CW/pusher rotation.
Assuming you are past that, the next thing is that there are at least 3 "generations" of the 12x6, there may be differences in the nomenclature molded into the blades.  The latest pushers are marked "F2B".
Offline John Cralley
« Reply #3 on: June 20, 2014, 09:58:08 AM »
Paul,
Back in the fifties in Army Basic training, if you could not tell your right hand from your left hand  n1, the drill Sgt. would make you carry a rock in your right hand!!! Do you think that would help you??
 LL~ LL~ LL~ LL~ LL~ LL~
Just kidding.  ;D
John Cralley
AMA 52183
Central Illinois
« Reply #4 on: June 20, 2014, 01:20:02 PM »
Thanks guys. I will post some pics later.
« Reply #5 on: June 20, 2014, 09:55:00 PM »
Well I did not read the package. Here ya go.
