  • June 16, 2025, 03:16:47 AM
Author Topic: Density Altitude and Temp Effects on E CLPA  (Read 875 times)
Offline Rudy Taube
  • Ret Flyboy
« on: November 11, 2009, 04:48:20 PM »
This is a spinoff from Walt's "Plett Orbit 25-H Clarification" thread.
The issue of temp and air density for OUR purposes is easily understood and calculated. If you want to dig deeper it gets somewhat complex with some really cool formulas and math. We are lucky to have some genius engineers on this forum (Paul Walker, Brett Buck, our moderator Dean, Igor, and others) they can give a better answer to the complex math than I can. But for the basics the comments below may help. I'm sure others will have comments too.   D>K
Dennis asked Paul  "is there an area where this issue (temp., & air density affects) is flat"? (Dennis, I am assuming that you meant flat as in not much affect?)
The answer is "yes" and "no".
YES there is a "flat" area: Basically if you live below 1,200" Alt., fly in temps between 45 and 85 degrees, AND fly E power, the affects of temp. and air density is not a big deal. Your plane will feel a little more crisp in the winter and a little softer in the summer, but very little difference. I think that the above conditions cover most CL pilots in the USA. On a 85 degree day you will still be at around 93% of the air density at sea level on a standard 59 degree day. You will not notice much difference in power or flying (unless you are at the very top of the CLPA world, they can tell the difference in performance when a drop of fly poop lands on the elevator during a flight!  LL~  )
As Paul mentioned, his E powered planes lap times remained the same on cold and hot days, and that this is due to the decrease in prop efficiency (thin air, fewer air molecules per sq. in.) was offset by the decrease in drag (thin air) on the aircraft. ..... IMHO: If this minor difference bothers you and you want the plane to fly the same in winter and summer you would need to decrease your lap times by around .1 sec in the summer. (this is a WAG, but I think it is pretty close, but only for the narrow alt. and temp conditions above)
NO there is not a flat area outside the above conditions. If you fly out west things change a lot from seasons if you live at high altitudes, or in very cold areas and fly below 40 degrees, then they do have an effect on our planes. If you fly at Denver (5,280') on a 90 degree day, your plane (and your body) thinks it is at 8,483' (that is the Density Altitude for that day) this is only 77% of the air available at sea level on a standard 59 degree day. The affect of this is that our props are about 23% less efficient, our wings and moving surfaces lose almost this much lift and force. Even we duffers can tell the difference now. Because we don't have throttles to help us (yet ;-) we may want to increase our flight speed over the ground (decrease lap times) to compensate. This is the only way we can get back to having enough air molecules pass over our wings per second to get our lift and control forces to be like they are at the lower density altitudes. Plane design and adjustments can help if you live high in the summer, but if your there for a contest only, then more speed is the answer. .....  (BTW: your body also suffers this decrease in efficiency if you are visiting for a contest)
Below about 3,000' density altitude there is not much change, above this alt. then our atmosphere thins out much faster as we go higher. As we can see, by a density alt. of 8,483' at Denver in the summer we are down to 77% of the air at MSL. Our E motor keeps putting out for us but the wet guys have both the prop AND the engine decreased by 23%, they have to experiment to find the right nitro, NV, etc. at a high/hot contest. In fact, because their wet power engine is affected too, they need to make adjustments for even the small density altitude changes at lower alt. and temp changes. But, to each their own. ;-)
If you want to find out the WX (temp, dew point, pressure) you need to calculate the density altitude for your area go here and type in your city:
      http://weather.aol.com/forecast/todays/us/ca/hermosa-beach/id/90254
If you want to calculate the "density altitude" for your area this is an easy calculator to use:
      http://wahiduddin.net/calc/calc_da.htm
Sorry this was so "wordy", I was too lazy to shorten it.  n~ .... To quote Mark Twain: "I wanted to write a short letter, but I did not have the time so I wrote a long one instead"
Regards,  H^^
« Last Edit: November 11, 2009, 08:41:57 PM by Rudy Taube »
Rudy
AMA 1667
Offline John Witt
Re: Density Altitude and Temp Effects on E CLPA
« Reply #1 on: November 11, 2009, 06:12:54 PM »
Thanks, Rudy, Nice to have a few benchmark numbers for that.
BTW, temperature alone will do it. I have seen it so hot in Phoenix AZ that Sky Harbor shut down because the jets couldn't leave.
There are other effects. When I was building electric cars, we just about couldn't run in PHX in the summer. The MOSFET junction temperatures in the controllers had a preset max of 140 deg F. Since there is a delta T between the MOSFET base, the liquid coolant and the air, the controller would overtemp after just a little bit of running. We didn't have the problem in Tucson which is generally about 6-8 degrees cooler than PHX, so we were right on the limit. I assumer the current crop of hybrids has that problem solved, I was doing this roughly 12 years ago.
John Witt
AMA 19892
Edmonds, WA
"Houston, Tranquillity Base here. The Eagle has landed."
Offline Dean Pappas
« Reply #2 on: November 11, 2009, 07:46:29 PM »
Hi Rudy,
Math aside, here in Joisey, near sea-level I find that I want the ability to easily adjust maybe 50 or 75 RPM between early morning and mid-afternoon conditions. That's why I like the idea of a "needle valve" that adds or subtracts a few micro-seconds from the timer output pulse. It's also why I don't bother with the fixed RPM mode.
I'll bet that density-altitude would be a good predictor of that small RPM change!
Dean
Dean Pappas
Offline Rudy Taube
  • Ret Flyboy
« Reply #3 on: November 11, 2009, 09:32:07 PM »
Hi John,
Your right about temp having a large impact. The 1st month I was at George AFB, in the CA desert, I had just finshed a flight when I saw a very large cloud of dust/sand just off the end of the runway. It was an F-104 that had tried to take off on a hot summer day while fully loaded, he rotated and just kept going on his main wheels, never getting off the ground. Amazingly the pilot survived, all that sand prevented any fire. It seems that the WX briefing, and the tower gave him the wrong temps. They gave him the OAT of only 102, he thought that they were giving him the runway temps (that we usually get) and used these in his TO comps. BTW the Rwy temps were over 125 degres, we were surprised that he could even get his nosewheel off the ground! I think I have RC models with larger wings than that plane has. But it sure looked cool!  8)  While I liked the sleek look of the F-104, I was very glad I flew a different plane.
RE: our E equip. temps. Your right, things have changed over the past 10 years. I'm not a Helli fan, but we in E-Stunt can thank them for giving us bullet proof ESCs that can handle a lot of work without overheating. As long as we keep some of our 58 mph winds directed at our ESCs they will work in OAT of at least 106 (this is the highest temps I have flown at). I think they can operate at higher OATs, but I can't!  n~
The motors of course want it as COLD as possible. Below zero and colder would make them happy. After talking to motor mfg. experts, I was told that their TOP end is "conservatively" around a sustained 140 degrees, OK up to 160 for short periods. Above these temps you begin to shorten the life of the motor, and risk permanently weakening the magnets. When you pass 180 to 200 you run the risk of epoxy failure holding the magnets. ..... The old rule of thumb that Dean and others have told us is still a very good one. If you can touch your motor right after a flight without pain. I use my nonflying fingers for this risky test!  ;)
Our modern batteries are the opposite from our motors. They are at their optimum somewhere between 90 and 110 degrees. At above 60 degrees and below 120 degrees they are fine for our needs. If they are real cold they don't put out like we need, if they are above 120 their life is shortened or destroyed. BTW, the same "if you can hold them without pain then they are OK" test is fine. If the OAT is lower than 50 degrees you may want to keep them warm (elec sock, warm ice chest, under your cat, etc. ;-) Not to worry during flight, our 1st several laps will usually get them warm enough for the WO. If you fly in cold ( <40) degree temps then you may want to direct most of the cooling air at the motor and less at the batteries.
The new ERC cars are amazing, you must be blown away by the new technologies in these cars.  y1
Regards,  H^^
Rudy
AMA 1667
Offline Dean Pappas
« Reply #4 on: November 12, 2009, 05:33:42 PM »
Rudy ...
You use your non-flying finger? That takes away all the incentive not to let things get too hot!
I actually warm my batteries to 100F if I can, and in my RC ships, I have taken to making a separate cooling entry for motor/ESC and another for the battery box. (the packaging is too tight in most Stunt ships to do this.) In cold (40F) weather, I have flown with the battery box inlet about 3/4 blocked.
Dean
Dean Pappas
