  • August 03, 2025, 09:20:22 PM
Author Topic: Deans ultra "Style" T connectors.  (Read 2753 times)
Offline Tom Luciano
« on: August 07, 2019, 10:21:51 AM »
Has anyone tried these knock off "T"   compatible connectors that are all over the place.
Are they as durable as far as soldering, etc.
Tom
AMA 13001
Re: Deans ultra "Style" T connectors.
« Reply #1 on: August 07, 2019, 03:01:53 PM »
Tom
I have, they suck.  Can't solider without destroying them.  Look at the delivery date to save virtually nothing.
Offline Tom Luciano
« Reply #2 on: August 07, 2019, 03:53:34 PM »
Thanks Ken!
AMA 13001
Offline William DeMauro
« Reply #3 on: August 09, 2019, 05:51:10 AM »
Tom,
   Most suck . I have and do use the "amass" ones and they work great. I actually prefer these over the real ones.  https://www.amazon.com/gp/product/B06XRZRGSC/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1    As far as soldering real deans or the fakes, one needs a good HOT iron and needs to pre-tin everything. A good 60-40 solder works well. There are many video's on you tube on how to solder deans. I DO NOT like those so called helper connections that some places sell to make soldering easier on deans or deans type plugs. To me they are double the work and add additional points of possible failure.
AMA 98010
« Reply #4 on: August 09, 2019, 06:07:56 AM »
5 pair for $1.49 what a great deal! To me, just looking at them they look like cheap plastic and not the red Bakelite of the original Deans. Let us know if you try them.
https://www.ebay.com/i/173686672634?chn=ps&norover=1&mkevt=1&mkrid=711-117182-37290-0&mkcid=2&itemid=173686672634&targetid=797643866846&device=c&mktype=pla&googleloc=9003887&poi=&campaignid=1498384308&mkgroupid=56281260165&rlsatarget=aud-674323410461:pla-797643866846&abcId=1139466&merchantid=118824747&gclid=CjwKCAjw7anqBRALEiwAgvGgm2iVV4uQEoju6bclh-2S9s0V5U9XxGFpHQ40Y0E1nx3wr76nbAEHShoCQpYQAvD_BwE
Motorman 8)
Tried them. They are a tiny bit larger than the real ones. They did work ok most of the time(not good enough for me). Have a very cheap feel to them. Don't trust them as I've seen a few not make contact when plugged in. I WILL NOT USE THESE!!!!
AMA 98010
Offline John Rist
« Reply #5 on: August 09, 2019, 08:14:13 AM »
The trick is to plug in a matting connector when soldering.  Keeps pins aligned while plastic is soft from heat.  I have use Hobbyking version with no problem.
« Reply #6 on: August 09, 2019, 09:18:33 AM »
That works.  The only place I use Deans anymore is for arming plugs.  it is easy to solder wires 90 degrees to the plug to keep them close to the fuselage side.  Anything else and you have at least 1/2" of unbending wire sticking out.  It also works well to tin both ends and flatten the wire end to make it lay flat on the connector.  Getting the shrink around that bend is sometimes frustrating but that is why we have epoxy.
Offline Larry Wong
« Reply #7 on: August 10, 2019, 03:37:33 PM »
This is what I'm switching over to XT-60 for arming and battery plug mount connection inside plane. they come in different colors also
Larry
« Reply #8 on: August 10, 2019, 08:54:05 PM »
My favorite.  Only problem I have encountered is a gradual loosening.  None have come apart in flight yet.  Still like the Deans for the arming plug.
Offline Larry Wong
« Reply #9 on: August 11, 2019, 06:11:33 AM »
Ken if it gets lose just spread the prong a little.
Larry
Online Dennis Adamisin
« Reply #10 on: August 12, 2019, 06:58:59 PM »
Hi Larry
The XT-60's with the mounting ears - where did you get those?  I'm using the MPI arming switches with the Anderson Power Poles - work nice but kinda clunky!
THANKS in advance...
Offline Larry Wong
« Reply #11 on: August 12, 2019, 07:29:04 PM »
Dennis I think I got them on Amazon ask for XT-60 mount in R/C cars trying to attach pix but to big !
Larry
Offline Larry Wong
« Reply #12 on: August 12, 2019, 07:31:50 PM »
another on out side
Larry
Offline Larry Wong
Larry
Offline John Rist
« Reply #14 on: August 13, 2019, 07:29:55 AM »
Hi Larry
eBay also has many listings.  Just search on XT69E-M  As cheep as $1 if you are willing to wait for them to be shipped from China. For US suppliers around $2.10 each if you buy 6.
Offline TDM
« Reply #15 on: August 13, 2019, 07:41:00 AM »
I use the Deans knock offs and i am happy with them. Tin both sides before soldering and whatever you solder connect the plug to the mating side, that will stop the plug from distorting during the solder operation.
« Reply #16 on: August 13, 2019, 11:11:34 AM »
another on out side
I usually use original Deans for that.. as even if it's accidentally on backwards it won't fried anything. But the XT-60 looks to be a good option.  :)
Offline TDM
« Reply #17 on: August 13, 2019, 11:40:06 AM »
What I do not like about the XT connectors is how hard are they are connected or disconnected.
« Reply #18 on: August 13, 2019, 02:14:14 PM »
XT60's are considerably safer.  A 1/2 way closed Deans is an open hot wire.  With XT60 the connection is closed before the contacts touch each other.  No sparks either and I have had sparks with Deans.
