  • June 17, 2025, 03:47:25 PM
Author Topic: Battery cell difference  (Read 692 times)
Offline Larry Wong
« on: April 21, 2013, 05:54:42 PM »
Got 8 flights in today, on one of the flights I had battery problem, after landing I check the battery (Cells) it was a 14.8v  cell counts were 38.5  38.5  38.6  34.7   readings at 15.8V   after battery cooled down the 34.7 went up to 37.7 ? the battery was puffed up also, Question is what is OK  on difference on cell count that's OK ???
when I charge the battery up it seams to be normal .... HB~> HB~>
Larry
Re: Battery cell difference
« Reply #1 on: April 21, 2013, 06:46:56 PM »
do you balance your batteries every time you charge?
Offline Larry Wong
« Reply #2 on: April 21, 2013, 06:52:22 PM »
Yes I use a Cell-Pro 10 HB~> HB~>
Larry
Online Bob Hudak
« Reply #3 on: April 21, 2013, 08:18:47 PM »
Not uncommon to have 1 cell out of the 4 go bad, the 3.47v cell is most likely culprit. If it's still under warranty contact the manufacturer and send it back.
350838
Offline Larry Wong
« Reply #4 on: April 21, 2013, 08:30:10 PM »
Thanks for the feed back but I think I got my use from them it's almost 2yrs old. just can't tell when it's time to go till it happens!!!!
Larry
