  • July 18, 2025, 08:56:11 PM
Author Topic: Crazy Ivan - Irregular Boost/Brake on Igor Timer  (Read 2631 times)
« on: November 01, 2022, 12:40:23 PM »
Mike Scott asked me to put this out to our electric crowd.  It is an Igor Active timer on a Spin 66 std. ESC.  What causes this crazy boost/brake? It does it everywhere except in level flight.
https://www.youtube.com/shorts/PatwoMMgSfA
Ken (for Mike)
Re: Crazy Ivan - Irregular Boost/Brake on Igor Timer
« Reply #1 on: November 01, 2022, 08:28:18 PM »
I couldn't hear it well enough to know what's going on.  Could you describe the phenomenon?
If it boosts when it should brake and then seems to get "stuck" in boost, and brakes when it should boost and seems to get "stuck" in brake, then I'd bet money that the sensor is backwards.
« Reply #2 on: November 01, 2022, 08:43:58 PM »
If you can turn the volume up it is clear.  I hate it when the "tube" puts a video into the "short" category with no controls.  Listen during the 8 and you can hear the boost/break going off 4-5 theme in each loop.  Mike has had a sensor come loose in the fuselage.  It acted differently.  Sort of random.  This has a pattern.
« Last Edit: November 01, 2022, 10:06:59 PM by Ken Culbertson »
Online Brent Williams
« Reply #3 on: November 01, 2022, 09:43:02 PM »
What are the settings of his timer?
« Last Edit: November 01, 2022, 10:10:46 PM by Brent Williams »
« Reply #4 on: November 02, 2022, 11:38:50 AM »
Mike replaced the timer and the problem went away.  I guess it got old. LL~
Probably never know the cause.
Online Crist Rigotti
« Reply #5 on: November 02, 2022, 11:42:51 AM »
He replaced the accelerometer and timer.
Offline Igor Burger
« Reply #6 on: November 03, 2022, 01:13:23 AM »
Mike has old type of timer (red sensor, yellow connector) and it has permanent cable. I think that cable is broken (it is really necessary to fix cable in fuselage so that it cannot move during flight). New timers has cable on connector, so it is easy to replace or test. I am in contact with him, so we will see what is problem.
However there are many reasons for such thing, so may be it will be good to collect them. In such case it is good to check from top down:
-defect timer - such erratic run can be caused by broken cable, especially if it is older type with fixed cable, forces in model can move cables and if cable has bad contact, it makes unwanted reactions
-improperly mounted sensor, moving during flight, it can do all sorts of erratic inputs, do not expect that if it was loose once, the next time it will act the same way
-loose cable to sensor, also well fixed sensor can "hear" mechanical movements of cable during fligt, the cable must be fixed also (that is second reason to fix that  in fuselage)
-too high sensitivity can cause erratic impulses
-trim problem causing ill movements of model during maneuvers
-problem in power train - for example defect motor winding, bearings etc making motor loose power, power connectors, arming plug etc.
