Hubin timer FM9v, external push button with CC edge light 50 esc.
Found this out during ground crew safety drill.
Push the button and get the warning spin for 30 sec count down. Push the button again at 20 sec and motor still starts as normal at 30 sec. Button does not stop the count down. After 30 sec as the motor is running push the button and motor stops. Is this normal?
Any time arming plug is in, hang on to plane which is what saved the day.
