Greetings Amped up Flyers-
Background : My control line "restart" was with a Brodak Warbird profile acquired in an estate sale. I just flattened out the nose with my disc sander and grafted on a homemade fiberglass motor mount; mounting screws accessed from between the engine bearers. Although it flew great (until I crashed it) it had fundamental problems : 1) the motor (Neumotors 1905) is heavier than the designed for Fox 35 and 2) my chosen 4S2700 Lipo packs are longer than the space for the gas tank in the model. To balance it properly, the battery pack needs to extend past the wing L.E. by an inch which along with all the guts hanging out looked lousy.
Since I have a brand new Brodak Warbird profile kit and in need of a new airplane, I thought I would do something about it to neatly accommodate the guts and adhere to the usual R/C convention battery mount using velcro longitudinal shear pad and velcro wrap around strap. I have (2) other R/C models that use the same set of batteries so this is the best way to make good use of them.
So far, my Sea Hurricane Semi-Scale Stunt model (profile) has the wing framed up which is required in order to interface the modified fuselage nose to it. I am now designing the fuselage structural modifications, central of which is a battery mount plate starting at the high point of the wing and extends forward to pick up the firewall. The 1/2 inch balsa formerly above this plate will be deleted and a "lost foam" fiberglass battery hatch fabricated. Haven't completely decided how to treat the under side of the plate as it is mostly just fairing. Maybe stringers, maybe more lost foam? Trying to keep it light. The 1/16th ply fuselage doublers are being replaced with 1/32 ply to save some weight. Here are a couple pics of the modified plans with the motor and battery shown in their final positions. I will bring you along as I implement the modifications so others may try it as well.
Cheers,
Steve Manganelli
