  • July 12, 2025, 07:46:52 AM
Author Topic: blank  (Read 1493 times)
blank
« on: June 16, 2013, 09:05:50 PM »
blank
« Last Edit: September 08, 2021, 05:38:29 AM by Motorman »
Re: Continuous Flying
« Reply #1 on: June 16, 2013, 11:13:47 PM »
It's a function of charger capacity.  The number of batteries you need is a function of their charge rate.   If you use 2100 mA-hr per flight and fly at 9-minute intervals (each flight starts 9 minutes after the last flight), you need to be able to charge batteries at 2100 mA-hr * (1 A / 1000 mA) * (60 min / 1 hour) / 9 minutes = 14 A.  If you have batteries that will charge at 14 amps, you need 2.  I went last season with three batteries, charging them at 7 amps when flying continuously.
You are lucky to be able to run the cord out the back door-- a situation I hope to have someday.  Then you can get a cheap server power supply that will put out plenty of power.  The charger is the costly part.  I have a Thunder Power TP 820CD that does the trick.
« Reply #2 on: June 18, 2013, 03:02:48 PM »
Yep.  A brief Google search says you can charge those at 20 Amps.  If you use 3200 of those mA-hours per flight and fly at 9-minute intervals, you need to be able to charge batteries at 3200 mA-hr * (1 A / 1000 mA) * (60 min / 1 hour) / 9 minutes = 21.3 A.  Unless you want to wait a little longer between flights, you need 3 batteries.
« Reply #3 on: June 18, 2013, 03:46:45 PM »
Howard, I'm not sure how you're achieving what you're achieving, because your understanding of how to charge a LiPo battery is a bit off.
The control rule for charging a LiPo (and for a lead-acid battery, for that matter) is to push as hard as possible while holding the charge current and voltage within limits.  When you start charging the battery will accept more current, which is where your 20A limit comes in, but as the battery starts to charge up its voltage rises, at which point the charger must cut the current to the battery to keep the voltage within safe limits (usually 4.2V per cell, or 4.3V if you and the battery manufacturer are courageous or foolhardy).
I certainly see this when charging my RC packs -- the full current part of the charge cycle only lasts for ten or fifteen minutes, then the balance of the charge happens at the battery's own pace.  Keeping the charge to 4.2V/cell is critical, and is the reason for balancing chargers.
Charging at too high a voltage is believed to be one of the problems behind the fires in the Boeing 787, but if you chat with your old work buddies you may know more than I do at this point.
« Reply #4 on: June 18, 2013, 04:15:43 PM »
Correct, Tim.  Assuming constant current was wrong.  Both my chargers charge at constant current for awhile, then hold 4.2V/cell as you say, probably doing something fancy at the corner.  Hold on and I'll go charge a battery at 7A and see how long it takes.
« Reply #5 on: June 18, 2013, 05:49:04 PM »
OK, I'm back.  I used my fancy FMA software and computer interface to see what happens.  I set the charger for 7A max. It put in 1963 mA-hr.  Current ramped up for a minute, then held 7A for 14 minutes, then approximately exponentially petered out.  Total charge time was 22:51.  How about assuming that charge time = 9 minutes + .83 * capacity in mA-hr * (1 A / 1000 mA) * (60 min / 1 hour) ?  So the number of batteries you need to fly continuously at 9-minute intervals = 2 + the minimum number it takes to put in .83 * capacity at the max charge rate in 9 minutes.  For the Hyperion example, assuming just one more battery, putting in .83 * 3200 mA-hr at 20A would take .83 * 3200 mA-hr  * (1 A / 1000 mA) * (60 min / 1 hour) / 20A = 8.0 minutes.  So 3 batteries should suffice.  This is kinda crude.  Does it look OK, Tim?
I also see from my log that I don't fly at 9-minute intervals when flying continuously.  It's more like 15-20 min.  I'd better pick up the pace.
« Reply #6 on: June 18, 2013, 05:53:46 PM »
I've watched Tom Morris fly flight after flight, usually 6 in competition and several practice flights. He has, I think, 6 batteries and a huge 12 volt battery on a two wheel cart and has two or more charging.
That's the hard part.  If you don't have power at the field, it takes the huge 12V battery to fly continuously.
« Reply #7 on: June 18, 2013, 07:23:06 PM »
I don't know for sure but if LiPo batteries are like other batteries, then the speed at which they can accept charge depends on their construction.  So, "it depends".
It's probably safe to assume that all honestly-rated 20C batteries are pretty similar, but maybe not.
On the number of 12V batteries you need:
(3200 mA-hr)(0.001A/mA)(3600 sec/hr)(14.8V) = 170kJ.
(170kJ) / ((20 min)(60 sec/min)) = 142W
So if you have a little battery and a 150W solar panel, then you can fly all day (for Howard that's 150W on a cloudy day, I know).  Unless you pick up the pace -- then you need a 300W solar panel, and if you can fly more often than once every 10 minutes you're good.
Motorman, Howard and I are having fun, but this is your thread.  Slap us if we're too far afield.
« Reply #8 on: June 18, 2013, 11:04:57 PM »
on a slightly serious note,, one part of the equation to keep in mind,, IF your system puts a more intense load on the battery,, then you will potentially need to allow time to cool the battery before charging as well,,
Offline BrianW517
« Reply #9 on: July 17, 2013, 10:04:40 PM »
  H^^ Motor's like to cool off once in awhile also.  Z@@ZZZ
Offline Doug Knoyle
Re: Re: Re: Continuous Flying
« Reply #10 on: July 17, 2013, 11:57:39 PM »
Especially the low dollar motors with crappy bearings that appear to wear out in less than 1 season of flying. Haven't done any scientific testing, but it has become obvious after half a season has been put on a motor, that letting the motor cool between flights has a marked effect of smoothness at the end of the run. Pull it apart, measure the bearings, note loose tolerances, replace bearings and it runs like new -  back to back flights are again okay.  Thanks to Dave Denison for the schooling on bearing issues.
My low dollar motor experiments are over. E-32 here I come.
Cheers,
Doug
Sent from my Nexus 7 using Tapatalk 2
AMA 60591
