  • July 27, 2025, 09:43:50 AM
Author Topic: Composite Electric TWEENER(2enr)  (Read 1261 times)
Offline jose modesto
« on: April 29, 2010, 01:07:14 PM »
photos of my latest all composite shell construction PA model
span 66" re 775si
moments nose 10" tail 19.5"
current weight 66 OZ. Note if it was gas the model would weigh 58oz  and could support a 10 oz finish and come under my projected weight of 72oz.
Wing= 1/16" balsa skins with glass cloth and 1lbs foam
Fuse= 1/32" balsa,glass,.2 CFM
Stab=1/32" balsa,.5 glass cloth and .2CFM with
Flaps= carbon fiber,.5 glass cloth and balsa core
Fin, Rudder and Stab= balsa
E-quipment
powerplant= Orbit 30-14
Battery= TP 4200
Timer=Hubin or Zigrass
ESC=Shuiltzie f2b
This project was cast aside for 2months as i sulked at not getting the batteries that i wanted (TP 4000 brick packs) I'm not over it yet.
Jose Modesto
Kim Doherty
Re: Composite Electric TWEENER(2enr)
« Reply #1 on: April 29, 2010, 02:00:17 PM »
Very nice Jose !!! y1 y1
Congratulations on completing another adventure!
I really like your fearless approach to building your models. Job well done!
Kim.
« Reply #2 on: April 29, 2010, 03:13:23 PM »
Kim take a look at a new way to use Hunts lost foam system. 1/4 composite wing panels with wing tips.
Jose Modesto
« Reply #3 on: April 29, 2010, 03:18:28 PM »
What Kim said!
this is SOOOO cool.  Bringing it to PA???
Offline ptg
« Reply #4 on: May 01, 2010, 03:23:19 PM »
Jose,
Dude......REALLY!
Butterfly here, must learn ways of Zen Master.
Talk to me, teach me, 411 please.  I am in the midst of inventing a way to mold a fairly complex fuse shells for my electric.  Cheek cowls, compound curves, bumps, bulges, light, bla bla bla.  I playing with ideas but not satisfied with results.  There should be a way to suck this stuff up in a bag and have it come out really good.  So far I've only managed to do good on the suck part.
PT Granderson
Offline TDM
« Reply #5 on: May 01, 2010, 05:49:06 PM »
Jose good job.
May I suggest for the flaps and all the tail surfaces to use 1/32balsa .75 cloth bias at45 degrees and ribs inside like in a built up wing.
Other than that we are very much on the same page. Except for my take apart system.
Offline TDM
« Reply #6 on: May 01, 2010, 05:53:47 PM »
Jose the skin is sufficient you do not need the ribs. I will have a vertical spar and three half ribs on the rear section of the wing and that is it. If you need the torsional load just put the cloth at 45 degree bias.
