  • July 12, 2025, 05:19:07 PM
Author Topic: Collet remover  (Read 1025 times)
Online Larry Wong
Collet remover
« on: January 31, 2014, 09:29:11 PM »
I have 2 collet remover but they are to big , need  one that will remove a collet from a 15 size motor with a 1 1/2" spinner so the opening is about 1 1/4" to pull collet, any Idea's ? HB~> HB~>
Larry
Re: Collet remover
« Reply #1 on: February 01, 2014, 07:21:36 AM »
I saw a Post in a Electric R/C site about just that, I think RC Groups?
I know some are swithcing over to the "grub" screw type. Maybe not CL guys, but some in R/C.
Re: Collet remover
« Reply #2 on: February 01, 2014, 08:44:41 AM »
Go find a guy that runs the RC cars or even the local hobby shop if you have one.   They are all time changing gears and wheels.
Offline Alan Resinger
Re: Collet remover
« Reply #3 on: February 01, 2014, 05:57:35 PM »
One thing I've found with any type of collet holding device is to never fully seat the shaft into the collet or a collet onto a shaft.  Then when you loosen the prop nut you can tap on the end of the collet and it will release.  Same would be true for the shaft into the collet like a router would have.  Don't fully seat the bit into the collet assembly.  Loosen the locking nut and tap the end of the bit and it will come out.
Online Larry Wong
Re: Collet remover
« Reply #4 on: February 02, 2014, 08:10:12 PM »
Thank's Alan it work like a charm. #^  #^
Larry
