  • July 15, 2025, 04:38:05 PM
Author Topic: Collet question  (Read 2003 times)
Collet question
« on: March 13, 2015, 09:24:01 PM »
does anyone have an idea of where to find a 5mm to 1/4x28 electric motor collet? I've been searching on the web but the few (extremely few) pieces I've found are back ordered. The only one I've been able to find was a 5mm to 5/16x24. I suppose I could just use a 1/4x28 die and rework it but I'd like to just find the right one.
Re: Collet question
« Reply #1 on: March 13, 2015, 10:04:05 PM »
Why are you interested in dead French celebrities?  https://en.wikipedia.org/wiki/Colette.
Re: Collet question
« Reply #2 on: March 13, 2015, 11:50:21 PM »
randy, have you tried Tru-turn?
Re: Collet question
« Reply #3 on: March 14, 2015, 05:38:45 AM »
Randy,
I believe may have what you need.
I'll take a look.
Offline William DeMauro
Re: Collet question
« Reply #4 on: March 14, 2015, 07:16:52 AM »
I thought Tower might have some but I see the don't, unless you want the set screw type, which I've tried and didn't care for. I have a few of those. If you want them you can have them. Why don't you use the, Hyperion ADAP-50xl They are a 5mm shaft to a 6mm Threaded shaft that is threaded on the inside to 3mm. These are the most versatile and probably the nicest ones I have found as you can use them with almost any type of spinner you can find or have. RC dude has those in stock. and they are not expensive http://www.rcdude.com/product-p/hp-adap-50xl.htm
AMA 98010
Offline Alan Resinger
Re: Collet question
« Reply #5 on: March 14, 2015, 08:43:56 AM »
Randy,
Aren't you using an E-flite motor?  Their collet is 5mm and 1/4 - 28.  I use the all the time.
Alan
Offline Mike Haverly
Re: Collet question
« Reply #6 on: March 14, 2015, 10:24:25 AM »
E-flite is available at our local hobby shop in Covington.  Hobbytown in Spanaway should have them also.  They are inexpensive and work fine.
Online Howard Rush
Re: Collet question
« Reply #7 on: March 14, 2015, 11:09:47 AM »
I have extras from E-flites.
Re: Collet question
« Reply #8 on: March 15, 2015, 06:29:32 PM »
Alan,
I'm using a Cobra motor. And I know that E Flight has them but they are current sold out (online, anyway). I order a couple from some outfit call ReadyMade RC, but it's been a week and they haven't arrived. Maybe they will eventually. I will try Hobbytown.
Thanks, guys.
